Follow me
Am I missing something? Heat backdate.
I have read a bunch of threads about backdating the heat on my 82 SC.
Am I missing something... All that is needed are the pieces on the left and right of the fan and then run the heater hoses through the same holes down to the heat exchangers? What are the parts on the side of the fan called so I can buy them. Thanks guys and sorry if this has been covered a 100 times.
1982 911SC |
Senior Advisor
930-106-321-01-PH
Left Side Heater Duct, 911 (1965-74) (1975-89 for backdated heater) NOTE: May need to be tapped with hammer near mounting screws to achieve optimal fit. [More Info] $94.95 911-106-322-01-PH Right Side Heater Duct, 911 (1965-74) (1975-89 for backdated heater) NOTE: Will require modification for cars with air conditioning [More Info] $89.95 those are the 2 parts needed along with the hoses. some fitting around the distributor and if you keep the A/C, a little more fitting. SSI heat exchangers would be a good addition, they really pump out the heat.
08 Cayenne Turbo |
Capitalist and Patriot
Heat Ducts
You need two of them, one left and one right Pelican Parts - Product Information: 930-106-321-01-PH Pelican Parts - Product Information: 911-106-322-01-PH and the hoses, SCAT makes some nice aircraft quality check the classified ads, they show up from time to time
Former Test driver & Production Manager Singer Vehicle Design 2009 Cayenne GTS, '81 911SC RoW Targa (lot's of goodies), '86 535csi, '84 633 csi (turbo charged-sold) , '68 912 Targa (sold) , '69 911E (sold) "Dream it, Believe it, Decide it, DO it " |
ROW '78 911 Targa
Heater ducts. This page has them:
Porsche 911 & Carrera Heating & Ventilation - Page 2 There are tech articles on doing it as well. Aircraft spruce has the 2-1/2" sceet or scat hose you'll want as well.
Follow me
Thanks guys. I do have SSI's so thats a plus I guess.
1982 911SC |
You may also want to buy the square piece of engine tin through which the heater duct hose passes on the driver's side. On your SC this will have no hole for the hose.
1983 Porsche 911SC - Arrow Blue lightweight '74 Carrera look http://forums.pelicanparts.com/porsche-911-technical-forum/498568-overdue-intro-sc-hotrod-project.html |
This thread deals with the other issues that you rarely see discussed in heater backdate threads.
Heater Backdate on a '78sc |
I have all of those parts aside from the vent hose left over from my build. PM me if you want them.
Kirk
70T 2.7RS spec. 68L coupe |
Follow me
Can I not reuse the hot air duct I have now?
1982 911SC |
Senior Advisor
08 Cayenne Turbo |
Follow me
Thanks James, Just waiting to find a pair of used fan ducts now. Anybody?
1982 911SC |
Be sure to buy hose that is very flexible for the heat exchanger to duct connections.
I used some of the original style aluminum hose for my backdate and it was difficult to make the bends. I believe the orange Scat hose works best.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
Follow me
I was looking for new hose but I really don't want orange. I would prefer red or deep black. But didnt see any.
1982 911SC |
Banned
Heres a black one. Pelican Parts - Product Information: 901-211-195-01-M260
Here's the page. Porsche 911 & Carrera Heating & Ventilation - Page 1 Dont know why it says left side only. I have them on both sides. |
Follow me
Dipso, I have some of that already that im going to try to use. The one that goes all the way across the engine to the blower I will just cut and attach to the right side. Should be pretty easy.
1982 911SC |
ROW '78 911 Targa
I originally used the hose posted above for my backdate. Doesn't shape very well for the bends you'll need on the left side. It lasted a year. You can't remove it without wrecking it due to the aluminum liner. I now have the orange stuff.
I also tried to reuse the hose that ran the width of my engine compartment. It tough to cut cleanly to length, and then even harder to get bent right to connect at the heat exchanger. I ended up getting the orange hose from Scat. They might have black hose. Give them a look.
Banned
On my 3.2, I need that as well, correct? ISTR that there is no hole for the hose to pass through...
Tired Member
But you can ignore all of this if a PO tossed the adapters and used 60mm hose everywhere.
Glenn Daily Driver - '78 911SC RoW Endurance Racer - '85.1 944 Street/Track Project - '86 951 Race Project - 944 Spec |
Follow me
Does anyone know the part number or name of the engine tin that the hose goes through on the driver side?
1982 911SC |
