Call 911
Compressor Question for the A/C Experts
When recently doing a shaft seal replacement on my Denso 10P15C compressor, I noticed that the clutch friction surfaces were pitted and abraded:
![]() When the shaft seal leaks, oil is thrown out almost directly in the plane of the clutch faces. If oil is present, clutch could potentially begin to slip as A/C pressure builds and torque required to drive the compressor increases. From the look of these distressed surfaces, slipping was indeed occurring. My question – could slipping compressor clutches be a major player in the poor performance of 911 air conditioning systems?
Dave Kirk My Porsche restoreth my soul. |
Yes. Similar question to "Could a slipping clutch affect my acceleration rate"
Your compressor has to take refrigerant from a low pressure to a high pressure. If it is slipping......no good.
'87 Carrera - 2400 lbs of Track Beast!! '88 Carrera Cab - Too nice for the track. '85 Targa - Salvage title that was not caught! |
Looks pretty normal for an old AC compressor. Yours looks pretty good actually given the age. If it's slipping I would suspect compressor internals before the clutch.
This is about a 2001 Jeep for instance.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
Normal wear.
Things tend to tear and get hammered when they come together, ey! |
If the clutch were slipping enough to adversely affect the A/C efficiency the clutch surface would wear out within a much shorter period than has proved to be normal. |
Call 911
Thanks guys. Good, logical replies. I won't worry about clutch slippage causing my wife to complain about the lack of A/C in our 911. It's getting new hoses, expansion valve, and thorough cleaning of the evaporator. Will be recharged with R-134A plus proper amount of lubricant. Best of all, I asked for (and received) a Kuehl Vent for Christmas. This will permanently be aimed right in her face whenever she's in the car during a summer ride with blower fan on high.
Lot's of 'experts' on A/C on here.. This is the guy to really help you!!
70 911T Sold 81 911SC Coupe84 Mustang Turbo GT 66 Galaxy 500 Ragtop (my Mother bought it new) 88 Thunderbird Turbo Coupe 69 Torino Cobra (R) Code |
