Installing G50 onto a 2.7 RS engine
Just wondering, is it possible to connect a G50 gear box to a 2.7 RS engine, is it feasible??, would it be better than having a 915??, have heard that the G50 is a lot heavier.
Euro 74 Carrera 2.7
UK
Old 06-26-2002, 06:16 AM
Bill Verburg's Avatar
The G50 is a lot heavier, has fewer gear ratios available, requires major changes to the rear suspension, requires replumbing the pedal cluster on a pre 84 car. It will handle higher hp more gracefully than a 915. IMO a lot of hassle and expense for very little benefit. Yes, it bolts to an earlier case after a new flywheel clutch and pp are installed.
Bill Verburg
Old 06-26-2002, 09:26 AM
Does anyone know the actual weight of the G50 Tranny. I'm not Hercules, (although I'd like to think I am), and I can pick it relatively easily. My brother took it over to the shop and picked it up and out of a trunk of a sedan. From my crude muscle guages, I would guess about 150-200lbs. Is a 915 1/2 of this? Hard to imagine how it could be. So that said, when a G50 is said to be much heavier, were talking about 50-75 lbs? Definetly not enough to cause much of a notice. Especially in bloated late eighties cars like mine.
Old 06-26-2002, 09:45 AM
Senior Member
Hello
It will bolt up but the clutch is a problem.
You either have to manufacture a flywheel or a pressureplate
However the G50 trany will not fit into the 2,7 Carrera body.
The 950 trany wighst the same like the latest euro 915 with the oilcooler. The G50 was a bit heavier.
Other issues are the drive shafts from the G50 are different too.
Grüsse
Old 06-26-2002, 05:19 PM
Senior Member
Hello
I forgot to mention that the floorpan has to be "expanded" under the G50 shifter to clear the mechanismen.
Grüsse
Old 06-26-2002, 05:21 PM
Thanks guys
Sounds like its going to be too much work just to get a nicer gear change in my car
Euro 74 Carrera 2.7
UK
Old 06-27-2002, 02:55 AM
Senior Member
Hello
The G50 gearchange is different but not nicer !
Actuall wights from dry tranys in Al Si 8 Cu 3 material are:
915 with Oilcooler, front carrier and cluch TOB mechanismen: 60 kg
950 with carrier and cluch TOB mechanismen sans clutch slave cylinder 60 Kg.
With ZF limitet slip you can add 3-4 kg
Grüsse
Old 06-27-2002, 01:51 PM
CBRacerX's Avatar
Aha!
Danke Roland, I feel better about my G50 already!
Chris Brown
'87 Carrara w/3.6 plugging in shortly!
Old 06-27-2002, 03:13 PM
It would be interesting to see some weights of the G50s. I have never weighed one myself. Accordining to Steve Timmins website the G50 is 100# heavier than a 915. I find that hard to believe. Just monkey curiosity here, What was the source for your G50 weights Roland?
My 915/67 al case, cooler, pump, LSD, front carrier, clutch mechanism, no fluid, no starter weighs 122# (55.5 kg)
My similarly equipped mg case 915, w/o LSD weighs 95# (43kg) Both measurements done on certified/calibrated electronic scales.
Just from moving them around the G50 feels heavier, but that observation is not really significant.
Bill Verburg
Old 06-27-2002, 05:16 PM
Senior Member
Hello
The source is a bathroom unit that is 5% accurate. I need that thing to ship parts via mail or UPS
Anyway they are to heavy for UPS and get shiped in closed DB crate boxes.
Grüsse
Old 06-28-2002, 03:42 AM
