s_wilwerding's Avatar
Trunk supports
I need to buy new supports for my trunk lid. However, I have a whale tail on the lid. Is a stock support enough to hold up the lid with the whale tail?
If not, what's to be done? I'm getting sick of holding up the trunk with my head.
Thanks.
Steve Wilwerding
1998 3.4L Zenith Blue Boxster
2009 Meteor Gray Cayenne
Old 06-26-2002, 09:31 AM
Friend of Warren
Nope, you will need to double up on the supports. I would suggest two of the heavy duty Weltmeister supports.
Kurt V
Old 06-26-2002, 09:46 AM
Administrator
Jack Olsen's Avatar
Or... simplify.
See this link.
Old 06-26-2002, 11:42 AM
I use locking pliers on the shaft portion of the hood shock. Holds it up real nice and fancy!
Old 06-26-2002, 01:35 PM
MarkY's Avatar
Send a message via Yahoo to MarkY
Re: Trunk supports
Thanks.
If the whale tail came stock from the factory, you already have two shocks, one on each side. In this case, you can just replace both shocks. I prefer the OEM shocks, others have reported they've had some difficulty fitting aftermarket shocks. If the tail was an add on, purchase the double shock kit from Pelican and replace the single shock you currently have.
Mark
1988 Black on Black coupe
Old 06-26-2002, 01:54 PM
