a/c has saved me many a time from foggy windows, it is not just about summer driving. It's about cloudy, rainy, humid day driving as well. I sometimes mix a/c with a little heat to be comfortable and dry up the cabin. ![]() Bill |
AutoBahned
the G50 system adds substantial wt. to the car the 965 looks like a blob-mobile to me but does have superior comfort any car will need lots of long term maintenance - search those terms to see what to look thru the service history for BTW - what is your intent with the car? Will you keep it mostly stock or turn it into a hot rod or what? you must also get a PPI from a Porsche expert mechanic - not just an expert on all cars Last edited by RWebb; 01-02-2013 at 12:59 PM.. |
Always Be Fixing Cars
Going to keep it mostly stock but open to RoW and typical upgrades such as SSIs or hi comp pistons if a full rebuild were ever required. The car is meant to be a driver. There are cheaper drivers out there that are probably a whole lot more practical (E36 M3...) but I'm interested in these cars because they are:
-beautiful -practical to some extent -a package that holds together and rewards careful driving, don't require 10/10ths to enjoy and make every drive an occasion. -a reasonable store of value. not planning on retiring off Carrera or SC appreciation, am planning on a few thousand bucks a year in maintenance but also don't see the sale price of these cars going down any time soon if ever. I suppose I should have phrased that "a reasonable indulgence". |
Was the Carrera script a factory option on SCs? Is this typically painted on?
I'm guessing all ducktails on SCs were aftermarket? Is it wrong to like this look: http://media.photobucket.com/image/recent/jannekii/SC2007/1.jpg |
Ed M 86' Coupe |
'80 RoW 911 SC non-sunroof coupe in Guards Red It's not a Carrera.... It's a Super Carrera! |
AutoBahned
No.
No, it's a decal. Correct. The rear spoiler on an SC was one of three different types, all of which are considered "whale tails', depending upon the year and market. Ducktails were used in 1973 and 1974. JR |
Reiver
Ducks are more than eye candy...they work, and start working at normal driving speeds...you need to have the front rubber lip spoiler too tho for balance.
DT's are a favorite on early and up to 89 cars. Whales only look correct on Turbo's to me altho the factory put them on non T's too. |
It's all good news for us!
'81 924 , '85 944 , '78 911SC , '82 928 5.0L "They run best being run close to the ‘limit’ and done so regularly" - Grady |
Reiver
Most are fiberglass (the originals were fiberglass on a metal frame)...lots out there, do a search here....very wide cost spread too depending upon your choice.
Fiberglass paints well if you let it 'cure'. I have a new duck on my 911SC now painted rattle can flat black until it cures for awhile...you don't want resins bleeding thru or shrinking in places while they surface.[IMG] [/IMG]
SC 3.0 here and very happy with it. A important upgrade for me was throwing the trombone cooler to the side and installing a quality oil cooler in its place.
Saying that if heat can be a problem where you are and where you may drive to, look for one with a cooler already installed ![]() ![]()
Goose- "nothing a year in the tropics wouldn't fix" |
What is the cost of removing a whale tail?
Replace the entire decklid or repaint as req? Can one typically recoup costs by selling the tail? EDIT: should have searched. Here's a good summary for anyone else wondering: Possible to remove whale tail? |
Did you like the second Carrera you drove?
By the way, that whale tail contributed a huge amount toward canceling the prodigious lift created by the shape of the 911, while also reducing total drag - interestingly enough. Porsche created the spoilers in the early 70's in response to racers complaining about the very marginal high speed behaviour at and above 100 mph. The tails were not created for aesthetic reasons. The tail HAD to be used in concert with the front lip spoiler, however.
Interesting you said 964s seemed too pricey. I just bought an 89 Carrera after a few months of research. The 964s definitely seemed to be less expensive than the G50 cars and maybe priced about the same as similar condition SCs I found. I know I have read here and there some Porsche people saying a 964 may be the best bang for your Porsche buck right now.
Maybe prices vary quite a bot on these in different parts of the country.
1989 Carrera |
After owning a 964, it would be tough (for me) to go back.
Did you test a C2? The nice ones have already hit the bottom of the depreciation curve. They are on the way upward. Quickly, I predict. It is already happening (quickly) in Europe. ppi is your best friend, regardless of model. |
