?Cyl Temp Sensor
I'm putting in a new cyl temp sensor (From Pelican, of course) and I read the tech aritcle but have a question. I don't recall seeing any grommet inside the wheel well area to get the old one out. Did I misread it? Where exactly do I look for the grommet? Sorry if it's obvious but I did not see it.
Thanks,
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 06-28-2002, 08:28 AM
Chuck Moreland's Avatar
It's not really in the wheel well. It's in the sheet metal at the front of the engine. You will approach it through the wheel well tough.
Read this thread I did (under old username) that gives some pictures and description.
Head Temperature Sensor Replacement
Chuck Moreland - elephantracing.com - vonnen.com
Old 06-28-2002, 08:37 AM
Wonderfully detailed explanation (pics really helped) and thanks for the quick reply.
Buck
'88 Coupe, '87 Cab,
Old 06-28-2002, 08:53 AM
Buck,
Grease the grommet before jamming it in the hole. Life will be better.
Ned Monaghan
Ned NYNA 11
87 Carrera targa
98 BMW 528i
98 Volvo V70
Old 06-28-2002, 08:58 AM
If you grease, use silicon-based grease. Petroleum based will break it down over time.
Old 06-28-2002, 09:54 AM
I was wondering about what to use b/c I don't "think" there's anything on there now. I happen to have some anti sieze for spark plugs and that type of application...would it work?
Thanks,
Buck
'88 Coupe, '87 Cab,
Old 06-28-2002, 10:07 AM
I'm not sure about anit-seize. I just did it dry, no problems.
Old 06-28-2002, 10:27 AM
Buck,
I used vaseline as it was easier to push the grommet in the hole when lubed.
Ned Monaghan
Ned NYNA 11
87 Carrera targa
98 BMW 528i
98 Volvo V70
Old 06-28-2002, 11:15 AM
I mis read the comment. I was thinking about the threads on the sensor itself. Should I put something on the threads or will this mess up the readings for the sensor?
Thanks,
Buck
'88 Coupe, '87 Cab,
Old 06-28-2002, 11:35 AM
The sensor has a some stuff on it already, I believe it is thermal paste. You want to leave that alone.
Old 06-28-2002, 12:16 PM
I'm stuck...I can't get a socket wrench in there with enough room to turn and get the old sensor out. If anyone has a suggestion on how to get this out I'd love to hear it.
THanks!
Buck
'88 Coupe, '87 Cab,
Old 06-29-2002, 07:58 AM
Dude,
Know exactly where you are. I was stuck too during that phase and I had the engine out. This is what I had to do:
1. cut the wires so I can get a socket in there
2. Use the socket (6 point), or a brake-line wrench
3. Still ended up breaking the damn thing because after 100K miles of heat, it was welded in there.
4. Took the head to the machine shop and have them burn out the left over pieces of crap inside the hole, and rethread it with 1/8 pipe plug tap (craftsman tap-die set has one in it)
My suggestion: heat it up carefully with a torch if you can, if it is still inside the car, you may have to remove the metal sheet metal to have enough room. I do not remember if this is doable with the engine in the car.
In short, your easy 1 hour project has turned into a week-long project, and maybe the engine has to come out. Sorry dude, no good news here.
Old 06-29-2002, 08:21 AM
Finally got it out...went back out and got my hand in there and managed to get my other hand on top and get enough force to break it loose. Getting those grommets in place was LOTS of fun too.
Buck
'88 Coupe, '87 Cab,
Old 06-29-2002, 04:09 PM
