G50 to 3.0 eng stud problem
I’m trying to bolt a G50 transmission to a 3.0 engine, just stabbed the trans to the engine and guess what? The stubs from the eng. are to short!!! Can you remove/ replace these studs? What’s the process?
Old 06-30-2002, 10:16 AM
Jim Smolka's Avatar
Yes, you can remove the studs. Simply double or triple nut the ends of the studs. Remove with a wrench. Sometimes they are stuck, but this trick usually works.
'75 914-6 3.2 (Track Car)
'81 SC 3.6 (Beast)
'993 Cab (Almost Done Restoring)
Old 06-30-2002, 10:42 AM
