kens_74_911s's Avatar
turbo trailing arm bearing replacement
Can the rear wheel bearings be replaced on a 82 rear - turbo trailing arm without pulling the arm? I have done a standard bearing replacement before but a budy of mine is looking into doing this on his turbo body N/A car. Sounds like there may be two bearings pressed into the arm ?
Ken - ebay: wandrey1 , *0 , *00 , *01
74 911s NA Widebody /96 BMW 750iL /99 BMW 328i/ 2018 BMW X3
81 VW Caddy Pickup X2 now...
84,85x2 .86,87,944. 82-924,88-924s parted with inventory!
68, 70, 72, 73, 911~ 70,73 914 past P/cars
Old 01-29-2013, 06:02 AM
Recreational Mechanic
Nickshu's Avatar
Yes.
Rear Wheel Bearing Removal
Wheel Bearings, rear DIY
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches
PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing
Old 01-29-2013, 06:10 AM
abisel's Avatar
Forgive me, but the links above are not for a turbo trailing arm because the turbo arms use bearings much like the front wheel hub bearings.
Still, the tools shown in the links above (or something similar) could work to remove the outer bearing races that are pressed into the turbo arms. Also, there is a crush spacer use to pre-load the bearings once installed that will need to be replaced as well.
Items 7A through 7E below:
Old 01-29-2013, 06:56 AM
Porsche Crest brgs
Thanks I was looking at the Pelican parts catalog and did see the inner and outer bearings. I suspect they may not need as much installation /removal force and like you mentioned I did also see the inner sleeve. A set of seals would be required as well. Appreciate the help
Ken
Old 01-29-2013, 07:44 AM
This is a job that I'd suggest would be better done by a competent shop. It's not easy.
JR
Old 01-29-2013, 08:26 AM
non-whiner
mreid's Avatar
Do not be fooled! I've done both and the turbo bearings are so difficult that a shop will charge you upwards of $3000. I can remove the trailing arms and replace the bearings in both standard arms and be back on the road in about 6 hours. The turbo takes twice as long with four times the aggrevation. I will admit that I am not a professional shop, but I am a very capable diyer. The turbo is far easier with the arms off the car and on a press.
"Too much is just enough."
Old 01-29-2013, 09:44 AM
Around here, I've gotten it done for $500 per side.
JR
Old 01-29-2013, 09:49 AM
Nickshu's Avatar
Oh, sorry! I forgot the turbo uses dual bearings on the rear.
Old 01-29-2013, 10:09 AM
