Dash Swap Quesiton
Can you put an 85 dash into an 88 911? I thought that since the assembly was different (85 you remove the windshield, 88 you don't) that you couldn't swap the dashes out.
86FlatSix
I think the aircon vents are different for the 85 vs 86-89. I am also planning to replace my dash pad and looks like the 86 is different from the 85 below, not sure though.
74 BMW 2002 (rust rocket) 86 911 Coupe (weekend warrior) 09 997.2 C2 (semi-daily) |
A few years ago I put a late 80s dash in an 84. Reverse of what you are doing. I had to cut the center vent opening larger. Enlarge a few mounting bolt holes and the early dashes have 2 defrost vents while the new one has a large metal trim piece all along the back. Some trimming may be required for that. I posted it on this forum a few years ago so u can likely find it.
Steve 69 911e |
I wouldn't do it. Look for an '86-on dash.
JR |
ROW '78 911 Targa
my dash swap (964 dash in 84 carrera)
