Nice cage and doors!
Rich |
Cage out again and is now at the painter to get powder coated... Time for more cleaning:
http://forums.pelicanparts.com/uploa...1374961934.jpg http://forums.pelicanparts.com/uploa...1374961941.jpg http://forums.pelicanparts.com/uploa...1374961946.jpg I recieved some special aluminum half-of-a-hinge from the US. Now it is time to get them on the doors: http://forums.pelicanparts.com/uploa...1374962057.jpg http://forums.pelicanparts.com/uploa...1374962062.jpg http://forums.pelicanparts.com/uploa...1374962065.jpg http://forums.pelicanparts.com/uploa...1374962068.jpg |
Testfitting doors :)
http://forums.pelicanparts.com/uploa...1374962178.jpg http://forums.pelicanparts.com/uploa...1374962188.jpg http://forums.pelicanparts.com/uploa...1374962196.jpg http://forums.pelicanparts.com/uploa...1374962201.jpg The fit is really good! But requires a little work to match the fenders... http://forums.pelicanparts.com/uploa...1374962263.jpg http://forums.pelicanparts.com/uploa...1374962275.jpg |
Hey christian
Very nice build, and i am excited how it will look when its done. Mounting some lightweight doors is on my wishlist since years. Very cool. But i noticed something at your roll cage. The strut under the roof looks a little bit twisted, or is it just the picture? :confused: http://forums.pelicanparts.com/uploa...1375032007.jpg |
Hey Rob
Thank you. It will be good when done! The doors are really nice. I am exited to see them painted. I see your point. And it scared me ;) I checked once the cage got back from the powder coating. All straight! /Christian Quote:
I bought a set of the first generation big 930 brakes in the US. I still need to clean and check the calipers. But the discs went to my brake guy to have a small layer taken off. They are very straight and look great now:
http://forums.pelicanparts.com/uploa...1375599191.jpg http://forums.pelicanparts.com/uploa...1375599198.jpg http://forums.pelicanparts.com/uploa...1375599202.jpg |
Off topic, but I just unpacked a box for my dad. A set of 46mm Webers.
They look like pure gold imho: http://forums.pelicanparts.com/uploa...1375599583.jpg http://forums.pelicanparts.com/uploa...1375599592.jpg http://forums.pelicanparts.com/uploa...1375599596.jpg |
Great work; money well spent.
But please: cover your beautiful steering wheel ore use an old ragged one during all that nasty work. Would be a pity if it gets spoiled! |
Hey Christian,
I have been following your progress and admiring your build for quite a while. I think that you have some '78-80 1/2 front 930 floating rotors. Have you got the hats as well? What size wheel rims are you contemplating? Just wondering as I have modified a full set myself to fit 16" Fuchs on a 3.2 based build. Skål |
Hey Uwon
Yes you are just right. I have the hats as well. I just took then off when the discs were beeing cleaned. I will run 8 and 9 X 15" Fuchs. And I am also planning for a set of 9 and 10 X 15" Minilights :) Quote:
The door project is coming along nicely:
Left side almost there! http://forums.pelicanparts.com/uploa...1376936394.jpg http://forums.pelicanparts.com/uploa...1376936398.jpg http://forums.pelicanparts.com/uploa...1376936405.jpg Left side needs a little more: http://forums.pelicanparts.com/uploa...1376936413.jpg |
The tank filler came back from powder coting. And we made a bracket for it. I looks good, I think!
http://forums.pelicanparts.com/uploa...1376939112.jpg Testfitting: http://forums.pelicanparts.com/uploa...1376939149.jpg http://forums.pelicanparts.com/uploa...1376939166.jpg http://forums.pelicanparts.com/uploa...1376939201.jpg http://forums.pelicanparts.com/uploa...1376939207.jpg |
Left door almost there:
http://forums.pelicanparts.com/uploa...1377331602.jpg http://forums.pelicanparts.com/uploa...1377331610.jpg Pretty nice fit, I think :) http://forums.pelicanparts.com/uploa...1377331625.jpg The last part of the rain gutter on the right side is now welded on. It still needs some more work, but it looks good! http://forums.pelicanparts.com/uploa...1377331733.jpg http://forums.pelicanparts.com/uploa...1377331740.jpg http://forums.pelicanparts.com/uploa...1377331750.jpg http://forums.pelicanparts.com/uploa...1377331754.jpg /Christian |
Time for a little update. Rain gutters are done. Fenders and doors are done. And I am satisfied :)
http://forums.pelicanparts.com/uploa...1378541549.jpg http://forums.pelicanparts.com/uploa...1378541556.jpg http://forums.pelicanparts.com/uploa...1378541564.jpg http://forums.pelicanparts.com/uploa...1378541575.jpg http://forums.pelicanparts.com/uploa...1378541613.jpg http://forums.pelicanparts.com/uploa...1378541625.jpg http://forums.pelicanparts.com/uploa...1378541632.jpg |
Other small things done.
The two holes where the fuel filler connection goes through the fender are closed - welded from the inside and sealed: http://forums.pelicanparts.com/uploa...1378541859.jpg http://forums.pelicanparts.com/uploa...1378541862.jpg The plates where the battery boxes normaly are are now sealed and the fuse box holders are back on: http://forums.pelicanparts.com/uploa...1378541967.jpg http://forums.pelicanparts.com/uploa...1378541975.jpg |
Very nice project - any updates? Er der chance for at se den til track days med PCD? :-)
Yes, the car is at the painter right now. I am very exited to hear/see about the process and of course the final result :) Ja, jeg håber at være klar til foråret. Så vil den være et fast indslag! |
I have installed 930 brakes and rotors on a 3.2 Carrera and I don't think that I could have put 15" rims on the front. In my case there less than 10mm between the outside of the caliper and the inside of the 930 16" Fuch rim. Also, I had to put in a 6mm spacer to clear the spokes for the fronts. If it does not fit, you may have to cut down the diameter of the rotor on the lathe and reposition the caliper holes vis-à-vis the mounting ears on the hub. Your build keeps inspiring me. My build is co-incidentally also at the paint shop at this moment, albeit its not such an ambitious restoration as yours. |
First pictures from the painter! More should come next week :)
http://forums.pelicanparts.com/uploa...1383237834.jpg http://forums.pelicanparts.com/uploa...1383237834.jpg /Christian |
Hey Christian,
Looking good. Always rewarding when you see the final paint on. Keep those pics coming. Cheers..... |
Hey Uwon
Thanks! It is really great to finally reach this stage. More pictures: http://forums.pelicanparts.com/uploa...1383688015.jpg http://forums.pelicanparts.com/uploa...1383688028.jpg http://forums.pelicanparts.com/uploa...1383688111.jpg |
Last pictures from the painter:
Last prepping http://forums.pelicanparts.com/uploa...1384408131.jpg http://forums.pelicanparts.com/uploa...1384408186.jpg http://forums.pelicanparts.com/uploa...1384408191.jpg And now in the right color :D http://forums.pelicanparts.com/uploa...1384408205.jpg http://forums.pelicanparts.com/uploa...1384408215.jpg |
Christian,
Looking good. Exiting to get to this stage. Keep those pics coming. What type of paint did you use on the underside and wheel wells? Are you planning to supplement it with some type of gravel guard? Cheers...... |
Car back from painter!
Just took a few shots... http://forums.pelicanparts.com/uploa...1384631497.jpg http://forums.pelicanparts.com/uploa...1384631507.jpg http://forums.pelicanparts.com/uploa...1384631514.jpg http://forums.pelicanparts.com/uploa...1384631518.jpg http://forums.pelicanparts.com/uploa...1384631521.jpg And working on getting the engine back together: http://forums.pelicanparts.com/uploa...1384631700.jpg http://forums.pelicanparts.com/uploa...1384631705.jpg http://forums.pelicanparts.com/uploa...1384631709.jpg |
Ser godt ud Christian!
/Johan |
Tak :) /Christian |
Sure started with a thoroughbred. I'm joining thios build on 6th page so ill go back later and catch up to date. Can't wait to see what tricks u picked up along the way. Nice...
sub'd
Thanks! Really exiting :) I plan on using the Würth spray on gravel guard. /Christian |
Parts ready to get on the car:
http://forums.pelicanparts.com/uploa...1384806872.jpg http://forums.pelicanparts.com/uploa...1384806880.jpg http://forums.pelicanparts.com/uploa...1384806886.jpg Engine room getting back together: http://forums.pelicanparts.com/uploa...1384806906.jpg http://forums.pelicanparts.com/uploa...1384806913.jpg |
Sweet! Looking forward to the first light video.
Working a bit on the rear of the car.
Installed a nice jack pad/tow hook: http://forums.pelicanparts.com/uploa...1385404749.jpg http://forums.pelicanparts.com/uploa...1385404759.jpg And now for the new muffler :D http://forums.pelicanparts.com/uploa...1385404806.jpg http://forums.pelicanparts.com/uploa...1385404810.jpg http://forums.pelicanparts.com/uploa...1385404878.jpg http://forums.pelicanparts.com/uploa...1385404882.jpg With the flash on, one can see all the way into the header - no resistance at all... http://forums.pelicanparts.com/uploa...1385404886.jpg |
that will be nice...nice and LOUD I would guess... enjoy..you are doing great...keep making progress every day...that is the name of the game when it comes to car resto's... :-)
That is one gorgeous motor! So is the rest of the car.......
Johan |
Agree with Uwon, its coming along nicely :D
Nice car.. in Denmark, of all places! :-) SSI used to be a few blocks away until this Danish company came and bought up John's business, but I am flying over there in a week or two. All the way out in Viborg, but has anyone visited the showroom ? It would be nice to see if they used the same tooling and have the same quality (unless they shipped it all off to China) I want to bring back a pair of heat exchangers for a 72 3.6 EFI project.. and maybe some door pockets from another source over there. I am bringing a couple of f 72 Chevelle parts over for a cousin, so already in courier mode.
JP Group A/S http://forums.pelicanparts.com/uploa...1386874097.jpg http://forums.pelicanparts.com/uploa...1386874140.jpg Porsche 911 2,2T |
| All times are GMT -8. The time now is 01:42 AM. |
