Danish 911S driver
Danish Dynamite's Avatar
Another ST-build - this time from Denmark
Some information about the car: It is a 1972 911 2.4S. When I bought it in 2008 it looket like this:
The original engine was gone. The previous owner had bought a new 3.0 liter Carrera case and used some of the parts from the 2.4 liter to make an engine. It was not running very well, so I had it taken apart. I decided to make a good, solid street/track engine, that looks like this now:
It produces around 260 hp at the flywheel at the moment and it is great fun on the track. I also got the gear box rebuilt with a limitid diff. Pictures from the track:
I bought the car in Sweden in 2008. Some Swedes had made it into a G-model at some point. Here is a picture from their build.
My plan is to turn it into an F-model again. But with a twist - a 1972 ST.
Pictures of the build coming soon!
/Christian
Christian
1972 911 S - 3.0 MFI in the making of an ST:
http://forums.pelicanparts.com/porsche-911-technical-forum/733424-another-st-build-time-denmark.html
Old 02-10-2013, 11:05 AM
Administrator
Jack Olsen's Avatar
I'm looking forward to it. I hope it will stay yellow.
Old 02-10-2013, 07:28 PM
jsveb's Avatar
Sounds like a fun project.
Nice to see another Dane on board.
Old 02-10-2013, 08:55 PM
dshepp806's Avatar
Yes: YELLOW!!!!!!
BEST!
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 02-10-2013, 10:30 PM
Turbonut
Raceboy's Avatar
It's a pity that the original engine is gone, would be a neat to see an original 2.4S so close to my location
In case you're interested, I have a 2.4S engine with 2.2S pistons, ported MFI heads etc that I won't use, though it does not have original S case anymore.
Good luck with the project!
'83 924 (2.6 16v Turbo, 530hp),'67 911 hot-rod /2.4S, '78 924 Carrera GT project (2.0 turbo 340 hp), '84 928 S 4.7 Euro (VEMS PnP, 332 HP), '90 944 S2 Cabriolet
http://www.facebook.com/vemsporsche
Old 02-10-2013, 10:58 PM
totle's Avatar
Hi Crhistian,
Great numbers on the engine. Looking forward to follow your build.
Located just a little north of you:-)
Trond R.
1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc..
1972 914-6 GT replica project
1986 944 Turbo
Old 02-10-2013, 11:55 PM
Danish 911S driver
Thanks for the replies!
The car will be yellow again. From its birth it was light yellow - "Hell Gelb"
The Swedes made it a darker yellow, that I really liked, but I am going for the original color when it gets to the painter.
The engine is made withe these specs:
930/Carrera engine block
95 mm cylinders
JE pistons 10.5 comp. Adjusted to 10.2
Carillo rods
3.0 Euro Carrera/2.4/2.7 crank
Carrera 3.2 heads with new valves and guides. The heads were fitted with a special flange and drilled to accept the MFI injectors.
GE 60 cams
MFI setup with throttle boddies and stacks from a 2.2 S
KN aircleaners
Dansk Stainless steel heat exchangers
Stainless steel 2 in 1 out muffler.
I can recomend EBS Racing for parts!
In this trim it made 260 hp on the dyno. I have now replaced the heat exchangers with a set of 40 mm headers. I am also going for a pair of 42 mm throttle bodies, as the ones from the 2.2 are way too small for the Carrera 3.2 heads. That should add a bit of HP...
/Christian
Christian
Old 02-11-2013, 12:55 AM
Danish 911S driver
Some pictures of the the process of building the rear:
Unfortunately I don't have pictures of doing the rear fenders. The car had Carrera fender flares on it. The were not even and the previous welding was not very good! My body repair guy is really old school and very thorough. I got hold of a pair of reproduced ST steel flares that were welded on when the Carrera flares were cut of:
Test fitting the rear bumper and engine lid.
Yes that is 9x15 Fuchs. Probably from the front of an RSR. Never restored. I was lucky to find them a few years ago:
More pictures coming!
Christian
Old 02-11-2013, 09:02 AM
almost to pretty to change- who ever did teh first body change did well from the pics-
excited to see what comes from this
Old 02-11-2013, 09:06 AM
giovanni86's Avatar
look good!
what about chromed trim??
Old 02-11-2013, 11:30 AM
jsveb's Avatar
Look really good.
Who is doing the body work?
Old 02-11-2013, 01:37 PM
steel ST flares, original 9x15 fuchs, light yellow? Sounds like the recipe for a beautiful machine.
1983 Porsche 911SC - Arrow Blue lightweight '74 Carrera look
http://forums.pelicanparts.com/porsche-911-technical-forum/498568-overdue-intro-sc-hotrod-project.html
Old 02-11-2013, 06:46 PM
ShakinJoe's Avatar
I'm in!
'87 Carrera - 2400 lbs of Track Beast!!
'88 Carrera Cab - Too nice for the track.
'85 Targa - Salvage title that was not caught!
Old 02-11-2013, 07:09 PM
Danish 911S driver
Originally Posted by jsveb View Post
Look really good.
Thanks!
A great guy called Kaj. He is a retired coach builder/body repair man.
That would be the guy racing this thing:
Christian
Old 02-11-2013, 09:55 PM
Jaskas's Avatar
This is so cool! Good luck with the build! I have been browsing through for some st-flares for my car as well...
911-87 mit der 3.6 V-Ram und alles spaß
Old 02-12-2013, 12:10 AM
Danish 911S driver
Thanks!
I know the guy (Marek) that I got my flares from, has plenty more in stock. You can PM me for contact info if needed.
/Christian
Christian
Old 02-12-2013, 12:24 AM
Shaun @ Tru6's Avatar
Looking forward to the build, hope you can post a lot of the welding work, like rear quarter bumper sheetmetal. you have a rare 68.5-69 decklid.
Tru6 Restoration & Design
Old 02-12-2013, 03:03 AM
Danish 911S driver
I hope to be able to post pictures of that for you.
What identifies it as a 68.5-69 decklid? And how rare is that?
/Christian
Christian
Old 02-12-2013, 04:05 AM
Thank you, I'm considering going ST on my 73 at some point.
late 68 and 69 used a "3-bar grill." One in the center and 1 at each end. In 70, Porsche added 2 more bars since the grills so easily deform. These decklids therefor only have a center tab whereas 70-on grills have 3 tabs top and bottom.
The decklid is fairly rare.
Old 02-12-2013, 04:12 AM
Danish 911S driver
Originally Posted by giovanni86 View Post
look good!
Yes there will be chromed trim. I allready got the chrome euro headlights and euro front turn signal lenses - though the ones in the rear will be the US style, I like them all red and white
Christian
Old 02-12-2013, 08:04 AM
