-   -   Another ST-build - this time from Denmark (http://forums.pelicanparts.com/porsche-911-technical-forum/733424-another-st-build-time-denmark.html)
Danish Dynamite 02-10-2013 11:05 AM
Some information about the car: It is a 1972 911 2.4S. When I bought it in 2008 it looket like this:
http://forums.pelicanparts.com/uploa...1356946395.jpg
http://forums.pelicanparts.com/uploa...1356946420.jpg
http://forums.pelicanparts.com/uploa...1356946489.jpg
The original engine was gone. The previous owner had bought a new 3.0 liter Carrera case and used some of the parts from the 2.4 liter to make an engine. It was not running very well, so I had it taken apart. I decided to make a good, solid street/track engine, that looks like this now:
http://forums.pelicanparts.com/uploa...1360522633.jpg
It produces around 260 hp at the flywheel at the moment and it is great fun on the track. I also got the gear box rebuilt with a limitid diff. Pictures from the track:
http://forums.pelicanparts.com/uploa...1356946606.jpg
http://forums.pelicanparts.com/uploa...1356946614.jpg
http://forums.pelicanparts.com/uploa...1356897498.jpg
http://forums.pelicanparts.com/uploa...1356946744.jpg
http://forums.pelicanparts.com/uploa...1356946757.jpg
I bought the car in Sweden in 2008. Some Swedes had made it into a G-model at some point. Here is a picture from their build.
http://forums.pelicanparts.com/uploa...1356946906.jpg
My plan is to turn it into an F-model again. But with a twist - a 1972 ST.
Pictures of the build coming soon!
/Christian
Jack Olsen 02-10-2013 07:28 PM
I'm looking forward to it. I hope it will stay yellow.
jsveb 02-10-2013 08:55 PM
Sounds like a fun project.
Nice to see another Dane on board. :)
dshepp806 02-10-2013 10:30 PM
Yes: YELLOW!!!!!!
BEST!
Doyle
Raceboy 02-10-2013 10:58 PM
It's a pity that the original engine is gone, would be a neat to see an original 2.4S so close to my location :)
In case you're interested, I have a 2.4S engine with 2.2S pistons, ported MFI heads etc that I won't use, though it does not have original S case anymore.
Good luck with the project!
totle 02-10-2013 11:55 PM
Hi Crhistian,
Great numbers on the engine. Looking forward to follow your build.
Located just a little north of you:-)
Danish Dynamite 02-11-2013 12:55 AM
Thanks for the replies!
The car will be yellow again. From its birth it was light yellow - "Hell Gelb"
The Swedes made it a darker yellow, that I really liked, but I am going for the original color when it gets to the painter.
The engine is made withe these specs:
930/Carrera engine block
95 mm cylinders
JE pistons 10.5 comp. Adjusted to 10.2
Carillo rods
3.0 Euro Carrera/2.4/2.7 crank
Carrera 3.2 heads with new valves and guides. The heads were fitted with a special flange and drilled to accept the MFI injectors.
GE 60 cams
MFI setup with throttle boddies and stacks from a 2.2 S
KN aircleaners
Dansk Stainless steel heat exchangers
Stainless steel 2 in 1 out muffler.
I can recomend EBS Racing for parts!
http://forums.pelicanparts.com/uploa...1360684760.jpg
In this trim it made 260 hp on the dyno. I have now replaced the heat exchangers with a set of 40 mm headers. I am also going for a pair of 42 mm throttle bodies, as the ones from the 2.2 are way too small for the Carrera 3.2 heads. That should add a bit of HP...
/Christian
Danish Dynamite 02-11-2013 09:02 AM
Some pictures of the the process of building the rear:
http://forums.pelicanparts.com/uploa...1356944131.jpg
Unfortunately I don't have pictures of doing the rear fenders. The car had Carrera fender flares on it. The were not even and the previous welding was not very good! My body repair guy is really old school and very thorough. I got hold of a pair of reproduced ST steel flares that were welded on when the Carrera flares were cut of:
http://forums.pelicanparts.com/uploa...1329497557.jpg
http://forums.pelicanparts.com/uploa...1329497616.jpg
Test fitting the rear bumper and engine lid.
http://forums.pelicanparts.com/uploa...1356944187.jpg
http://forums.pelicanparts.com/uploa...1356903524.jpg
http://forums.pelicanparts.com/uploa...1356903583.jpg
http://forums.pelicanparts.com/uploa...1356944194.jpg
http://forums.pelicanparts.com/uploa...1356943688.jpg
Yes that is 9x15 Fuchs. Probably from the front of an RSR. Never restored. I was lucky to find them a few years ago:
http://forums.pelicanparts.com/uploa...1360512619.jpg
http://forums.pelicanparts.com/uploa...1360512624.jpg
More pictures coming!
saxen 02-11-2013 09:06 AM
almost to pretty to change- who ever did teh first body change did well from the pics-
excited to see what comes from this
giovanni86 02-11-2013 11:30 AM
look good!
what about chromed trim??
jsveb 02-11-2013 01:37 PM
Look really good.
Who is doing the body work?
kiwiokie 02-11-2013 06:46 PM
steel ST flares, original 9x15 fuchs, light yellow? Sounds like the recipe for a beautiful machine.
ShakinJoe 02-11-2013 07:09 PM
I'm in!
Danish Dynamite 02-11-2013 09:55 PM
Originally Posted by jsveb (Post 7267471)
Look really good.
Thanks!
A great guy called Kaj. He is a retired coach builder/body repair man.
That would be the guy racing this thing:
http://forums.pelicanparts.com/uploa...1360648346.jpg
http://forums.pelicanparts.com/uploa...1360648353.jpg
Jaskas 02-12-2013 12:10 AM
This is so cool! Good luck with the build! I have been browsing through for some st-flares for my car as well...
Danish Dynamite 02-12-2013 12:24 AM
Thanks!
I know the guy (Marek) that I got my flares from, has plenty more in stock. You can PM me for contact info if needed.
/Christian
Shaun @ Tru6 02-12-2013 03:03 AM
Looking forward to the build, hope you can post a lot of the welding work, like rear quarter bumper sheetmetal. you have a rare 68.5-69 decklid.
Danish Dynamite 02-12-2013 04:05 AM
I hope to be able to post pictures of that for you.
What identifies it as a 68.5-69 decklid? And how rare is that?
/Christian
Shaun @ Tru6 02-12-2013 04:12 AM
Thank you, I'm considering going ST on my 73 at some point.
late 68 and 69 used a "3-bar grill." One in the center and 1 at each end. In 70, Porsche added 2 more bars since the grills so easily deform. These decklids therefor only have a center tab whereas 70-on grills have 3 tabs top and bottom.
The decklid is fairly rare.
http://forums.pelicanparts.com/uploa...1360671145.jpg
Danish Dynamite 02-12-2013 08:04 AM
Originally Posted by giovanni86 (Post 7267194)
look good!
Yes there will be chromed trim. I allready got the chrome euro headlights and euro front turn signal lenses - though the ones in the rear will be the US style, I like them all red and white :)
