The car looks great :-)
I am also planning a ST project, where did you get the flares from and is the rear bumper ST or RSR? |
I got the steel flares from a danish guy called Marek. He had them reproduced and they are exellent quality. He can be reached at: early911parts@gmail.com I got the rear bumper in Germany from a guy who has ST-parts. A little wider than RS - a little narrower than RSR /Christian |
Hey DD,
Great project. Those flares are awesome. Do post lots of picks for us. Cheers... |
Pictures from taking the front apart:
http://forums.pelicanparts.com/uploa...1329497733.jpg http://forums.pelicanparts.com/uploa...1356944002.jpg The great guy (Kaj) inspecting the inside of the trunk ;) http://forums.pelicanparts.com/uploa...1356903288.jpg http://forums.pelicanparts.com/uploa...1356903184.jpg http://forums.pelicanparts.com/uploa...1360943071.jpg http://forums.pelicanparts.com/uploa...1360943089.jpg http://forums.pelicanparts.com/uploa...1360943307.jpg http://forums.pelicanparts.com/uploa...1360943452.jpg |
The car looket really nice in 2008 when I bought it, but over the four years of driving it, some signs of problems showed up:
http://forums.pelicanparts.com/uploa...1356944025.jpg http://forums.pelicanparts.com/uploa...1356945433.jpg We decided to attend it all during the build. These pictures are from the right side http://forums.pelicanparts.com/uploa...1356903713.jpg Both the inner and outer rocker panels need to be replaced and also where the door closes http://forums.pelicanparts.com/uploa...1361374124.jpg http://forums.pelicanparts.com/uploa...1356945760.jpg http://forums.pelicanparts.com/uploa...1356945811.jpg http://forums.pelicanparts.com/uploa...1356903878.jpg http://forums.pelicanparts.com/uploa...1357382040.jpg |
I'm subscribed to this !!! :eek:
Right side pictures:
http://forums.pelicanparts.com/uploa...1356945841.jpg http://forums.pelicanparts.com/uploa...1356904339.jpg http://forums.pelicanparts.com/uploa...1356903484.jpg http://forums.pelicanparts.com/uploa...1362077180.jpg http://forums.pelicanparts.com/uploa...1362077195.jpg Some work had to be done inside of the fender towards the door closing panel: http://forums.pelicanparts.com/uploa...1362077184.jpg http://forums.pelicanparts.com/uploa...1356903441.jpg http://forums.pelicanparts.com/uploa...1357382242.jpg |
Der er nu ikke så meget Oluf Sand over det. :)
just watch out for the brown recluse! |
While waiting on the body work, I collected a new exhaust system. The old one was from DANSK and a bit too small, so I took it off, cleaned it and sold it:
http://forums.pelicanparts.com/uploa...1357496333.jpg Before and after initial cleaning. What a difference! (And part of my patient girlfriend...) http://forums.pelicanparts.com/uploa...1359221567.jpg http://forums.pelicanparts.com/uploa...1359221575.jpg http://forums.pelicanparts.com/uploa...1359221578.jpg After a lot of elbow grease and a lot of Autosol: http://forums.pelicanparts.com/uploa...1359309503.jpg http://forums.pelicanparts.com/uploa...1359309519.jpg http://forums.pelicanparts.com/uploa...1359309526.jpg http://forums.pelicanparts.com/uploa...1359309567.jpg http://forums.pelicanparts.com/uploa...1359309579.jpg The old mufler got cleaned up too: http://forums.pelicanparts.com/uploa...1359309738.jpg |
Time to focus on the new system. I got a pair of headers from EBS, that I painted black with heat resistant paint:
http://forums.pelicanparts.com/uploa...1359221248.jpg http://forums.pelicanparts.com/uploa...1359221364.jpg http://forums.pelicanparts.com/uploa...1359221417.jpg http://forums.pelicanparts.com/uploa...1359221426.jpg http://forums.pelicanparts.com/uploa...1359221433.jpg Looks nice on the engine! And the fit was perfect. I am runing Carrera 3.2 heads on my 3.0 Carerra engine and the ports and the header was a perfect match! |
The new exhaust is from DANSK in ST-style. It was grey when I got it, but I wanted it to be black...
http://forums.pelicanparts.com/uploa...1364034617.jpg http://forums.pelicanparts.com/uploa...1364034605.jpg http://forums.pelicanparts.com/uploa...1364034637.jpg I found some perfect clamps for the pipes that I also painted black: http://forums.pelicanparts.com/uploa...1364034951.jpg http://forums.pelicanparts.com/uploa...1364035159.jpg I am a little concerned about how much noise this system makes?! http://forums.pelicanparts.com/uploa...1364035576.jpg http://forums.pelicanparts.com/uploa...1364035389.jpg http://forums.pelicanparts.com/uploa...1364035368.jpg http://forums.pelicanparts.com/uploa...1364035402.jpg http://forums.pelicanparts.com/uploa...1364035409.jpg |
More work on the front of the car.
The ugly ducklings where the battery cases had been and the previous owner had made a mess are gone and nice new (original thickness) plate is fitted instead: http://forums.pelicanparts.com/uploa...1360512137.jpg http://forums.pelicanparts.com/uploa...1360512157.jpg http://forums.pelicanparts.com/uploa...1360512180.jpg http://forums.pelicanparts.com/uploa...1360512189.jpg The front pad cleaned up nicely and we decided not to replace it: http://forums.pelicanparts.com/uploa...1360512202.jpg Test fitting the closing plate: http://forums.pelicanparts.com/uploa...1360512504.jpg http://forums.pelicanparts.com/uploa...1360512560.jpg http://forums.pelicanparts.com/uploa...1360512595.jpg |
Hey Christian, great work! I want to point out though that the sides of front bulk head should be on the inside of the lateral supports instead of wrapped around the outside of those like you show. It might affect the fit of the fenders and hood as you would have made the front of the car narrower than it should be.
Great looking build! I just noticed that you appear to have no rain gutters! That was some effort by the previous owner.
That is true. The previous owner took them off in the attempt to make a Yellow Bird. And I hate it! Either I am having them reaplied in some way or I am having the entire roof replaced... Gotte have rain gutters for my car. /Christian |
Hey Christian, thanks! I'm still working through some final details before a shake down test, but at least I'm in good shape right at the beginning of the season. :)
So, you think you'll reapply the rain gutters. Wow, that seems daunting. Are you considering a lightweight roof insert and full cage? |
My body work guy is considering either to remanufacture rain gutters and weld them on the existing roof, or to replace the whole roof with one that has rain gutters. I want the original look back! I will go for a full cage at some point :) |
| All times are GMT -8. The time now is 06:59 AM. |
