carl74344's Avatar
Unhappy transmision mount problem
today i went to change the trans mounts. the first one went fine. the other when i went to remove the center bolt it came out real easy. i did not think much of it. i put the new mount in but could not get the bolt to start.
the bolt had a thin wire rapped around it. turned out to be the threads from the nut end.
i am going to try to run a tap in the hole and a die on the bolt.if this does not work can i put a heli coil in there? the PO must have air gun the he-- out of it.. has anyone had to fix a trans mount like this? thanks carl
car-1982 911sc
1982 guards red 911 sc work in progress
Old 02-17-2013, 09:16 PM
Senior Advisor
James Brown's Avatar
the last one in is always the one that strips, try to loosen all the bolts (support the engine) and start all 4 bolts. sounds like the trans mount might be stripped, i have seen oversized bolts for this problem, might search for this
08 Cayenne Turbo
Old 02-17-2013, 09:45 PM
schumicat's Avatar
don't use a tap, use a thread chaser. a tap can cut up the threads and make it worse. a tap is designed to cut new threads whereas a chaser is designed to clean existing threads. you can get chasers on amazon.com.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 02-18-2013, 05:51 AM
Send a message via Skype™ to Porboynz
If you are talking about the 2 large bolts that go through the centre of the trans mounts into the blind holes, then once stripped its time to repair with a helicoil or timesert. The threaded section is only about 10mm deep. You must make sure the bolts do not bottom out when torquing up or the threads will pull. Its easy to leave a washer out or use a replacement bolt thats a little too long. The originals have a nice tapered point but I always get these bolts started by hand with the 2 bolts holding the trans mounts in place loose, to avoid crossthreading. This happened to me and I used a helicoil, been fine for 15 years now.
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 02-18-2013, 11:09 PM
Here's a discussion on your very problem from a few days ago!
repairing trans bolt holes
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 02-19-2013, 05:50 AM
Recreational Mechanic
Nickshu's Avatar
Wow, I just ordered new engine/trans mounts. Will be extra careful on the trans bolts! Thanks!
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches
PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing
Old 02-19-2013, 06:15 AM
carl74344's Avatar
thanks guys. i am on my way to having it back on the road....carl
Old 02-20-2013, 01:17 AM
