Part # for these wires?
I couldn't find these in my PET. Anyone know the pn?
They are two wires that go from this connection point through the engine tin paneling to a magnetic sensor on the flywheel. Must be RPMs?
The rubber coating is cracking off so I want to replace the wires.
'69 911E Targa
'87 Carerra Coupe
Old 02-21-2013, 08:42 PM
Cooper911SC's Avatar
Likely not sold seperately.
You will need to order the sensor, which will come with the wires and the appropriate connector on the other end.
Sorry for the bad news...
Old 02-21-2013, 08:57 PM
Go-Kart Mozart
JAR0023's Avatar
Search term "reference sensor". You'll get plenty of hits. Couple of threads in the last week. The white wire is your cylinder head temp sensor. The other two are the same part. One is your reference sensor, the other is your speed sensor. There is a BMW part that is virtually identical and half the price. Pelican sells both. -J
Old 02-21-2013, 09:39 PM
French Import
zippy_gg's Avatar
A fellow Pelican sent me this link Bosch 0261210002 Engine Crankshaft Position Sensor : Amazon.com : Automotive and I bought 2 of them for less than half the cost of the "Porsche" part. They are Bosch parts.
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 02-22-2013, 07:38 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Yep the BMW part does indeed work just fine. Used them myself on a few friends' cars.
0 261 210 002 which appears to be from E24 (635 and 735) and E28 (535) BMW models. On Pelicanparts, this equates to the sensor for 535 cars from 1985-1988 and 533 cars from 1983-1984 which is BMW part number 12-14-1-708-619-M14
These sensors do work and the plugs are exactly the same. So no cutting/splicing like an O2 sensor. So there is no need to buy the actual Porsche part number!
Note that when you remove the sensors, one of them is captured in the mount by a sleeve. You have to be very patient removing the sensor so you don't booger up the sleeve. The sensor is junk anyway, so no worries about damaging it. Just don't want to mangle the sleeve.
Kevin L
'86 Carrera "Larry"
Last edited by KTL; 02-22-2013 at 07:48 AM.. Reason: removed bad link to Bosch reference manual
Old 02-22-2013, 07:47 AM
KTL KTL is offline
Schleprock
KTL's Avatar
By the way, while you're in there? Take a look at that fuel line just above your circled part of the picture. That hose is known to crack and leak.
Kevin L
'86 Carrera "Larry"
Old 02-22-2013, 07:49 AM
Thanks everyone! Yes, I am doing the fuel lines too. This is actually the reason I dropped the engine. But now I'm addressing other maintenance things while the engine is out.
'69 911E Targa
'87 Carerra Coupe
Old 02-22-2013, 10:01 AM
scarceller's Avatar
The top white harness on the bracket is the CylHeadTemp sensor. If the white harness on the bracket only has 1 wire connector then also change the CHT sensor to the later 2 wire one while your at it.
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 02-22-2013, 10:27 AM
Synchro Joe's Avatar
Anyone been able to pin down and source the 3 female connectors for the cyl head temp sensor and crankshaft position sensors?
After being exposed to engine heat for 25+ years they become brittle and start falling apart. I've learned that cyl head temp sensor will prevent starting on my 3.2L when the connector is loose.
Horsepower is how fast you hit a wall.Torque is how far you will take the wall with you.
Old 04-29-2013, 10:28 AM
scarceller's Avatar
I have no idea on the ref/speed sensor connectors.
But I think the CHT is the same style as a fuel injector, if so these are easily available.
Sal
1964 356SC (SOLD)
Old 04-29-2013, 10:37 AM
ROW '78 911 Targa
timmy2's Avatar
Post a picture of the connector, I may have a source.
Old 04-29-2013, 10:40 AM
scarceller's Avatar
Pics are on the first post of this thread.
I assume he needs the engine harness side (females). The sensor side comes with the sensors.
The top white connector is the sensor side for the CHT and I think this is a standard fuel inj type connector.
The bottom 2 black connectors are the same and these are the Ref and Speed sensors, these have 3 wires. No idea where to get these?
Sal
1964 356SC (SOLD)
Old 04-29-2013, 10:46 AM
3-pin AMP connector.
3-Pole Female AMP Jr Timer Connector Kit $24 each
http://www.summitracing.com/parts/smp-s745?seid=srese1&gclid=CJbix7m48LYCFcLc4AodOkwAOg $13 each, but not "euro"
Standard Motor Products S745 Pigtail/Socket : Amazon.com : Automotive $13 and free shipping
Mike Bradshaw
1980 911SC sunroof coupe, silver/black
Putting the sick back into sycophant!
Old 04-29-2013, 10:52 AM
scarceller's Avatar
Another source:
BWD PT365 - Electrical Connector | O'Reilly Auto Parts
Sal
1964 356SC (SOLD)
Old 04-29-2013, 11:07 AM
Love this place!
Is there a p/n for the cyl head temp sensor connector (2 pin) harness side?
I don't see it called out as a separate item in the parts books. If this one fits the job.
Old 04-29-2013, 11:29 AM
scarceller's Avatar
First, verify the CHT connector is a fuel injector connector.
Try plugging the CHT connector into/onto a fuel injector. Try injector #3 as the CHT harness should easily reach injector #3. DO NOT attempt to start the engine! You are just verifying that the CHT sensor connector is exactly like a fuel injector connector.
If it is a standard FI connector you can get these on ebay cheap:
Fuel Injector Connector Bosch Lucas EV1 1 Connector New | eBay
Love this place!
Sal
1964 356SC (SOLD)
Old 04-29-2013, 11:37 AM
ROW '78 911 Targa
timmy2's Avatar
I'm on my phone so can't zoom on pics. If they are just junior timer connectors I can source them for a lot less than most...
I'll look at it tonight when I can zoom!
Old 04-29-2013, 11:39 AM
ROW '78 911 Targa
timmy2's Avatar
Ok, found them at mouser for you. Part numbers are:
571-2821911 for the 3 pin and 571-826008-5 for the 2 pin.
The rubber boots are not correct for them at mouser or other places. I imported mine from Europe and if you PM me, I'll send you them for my cost. I have a bunch for the engine harnesses I'm building.
Part number for the female pins is 571-925596-1
Last edited by timmy2; 04-29-2013 at 06:16 PM.. Reason: Corrected part numbers, added pin part #
Old 04-29-2013, 12:06 PM
dshepp806's Avatar
This group is bad-arse!
BEST!
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 04-29-2013, 01:34 PM
ROW '78 911 Targa
timmy2's Avatar
I corrected a part number in my earlier post and added the part number for the contact pins.
Old 04-29-2013, 02:13 PM
