mcinturff's Avatar
CIS Idea
Wouldn't it be neat if you could replace the air flow sensor with an actuator controlled by a simple computer taking readings from a MAP sensor?
1988 930 Cab - Peru Red
1983 911SC - Black
1992 964 C2 Cab - Amazon Metallic Green
Old 02-22-2013, 02:03 PM
mcinturff's Avatar
75 views and no hits? Come on guys.
1983 911SC - Black
Old 02-22-2013, 08:11 PM
What's your goal?
If the goal is to add some definitive feedback control to CIS then I think it would be easier to replace the WUR with an actuated valve that had its position driven by feedback off an O2 sensor. I think this would be much simpler from a controls standpoint. The CIS air flow "sensor" is, in my opinion, a fairly elegant mechanical solution to a difficult problem.
I think it would be difficult to get an appropriate actuation curve for the fuel distributor based on MAP alone. (You might stand a chance with MAF, but I think the big issue is ensuring you have proper air/fuel mix - and you just don't get that with MAF or MAP alone.)
Old 02-22-2013, 08:58 PM
mcinturff's Avatar
Good points. The idea is to be able to run hotter cams without worrying about the intake reversion messing with the airflow sensor. Just a bored engineering student here procrastinating with regards to my Differential Equations test.
1983 911SC - Black
Old 02-22-2013, 09:02 PM
Scott R's Avatar
Hot hot of a cam are you thinking? Reversion is not something I've had an issue with.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 02-22-2013, 09:37 PM
If you went to that much trouble, you might as well convert to EFI and eliminate the rest of the mechanical complications of CIS.
Old 02-22-2013, 10:09 PM
