Alternator rebuild- While I'm in there list
I'm getting ready to remove the alternator on my 87 911 coupe for a rebuild to correct an overcharging problem. I'll have bearings and bushes replaced while it’s out. Anything else that is worth doing while I have the alternator and fan, etc out?
’87 Venetian Blue Coupe |
Caveman Hammer Mechanic
Full suspension rebuild?
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
A good shop will replace all of not most wear items on the alternator, including diode.
Spray the fan housing with a light coat of Rustoleum Matte Nickel Metallic brilliant metal finish - rattle can paint. Or a similar finish.
Sergio The GT Lid Whisperer PCA 42yrs - National DE Instructor / Ex-RGruppe #197 '19 718 Cayman S (9th Porsche/1st with PDK) '14 Subaru Forester XT (Porsche support vehicle) |
Tired Member
That and a 3.6 swap.
![]() Seriously though,
Glenn Daily Driver - '78 911SC RoW Endurance Racer - '85.1 944 Street/Track Project - '86 951 Race Project - 944 Spec |
Member 911 Anonymous
You guys kill me. lol
okay, check the ground wire for cracks or looseness or fouled connection, clean or replace if needed. check for debris build up on top of the cylinder heads, clean and vacuum or blow it out the heads will cool better. That is pretty much all you can do wyait. fancy ups would be powder coating or polish the fan and or housing ( you can check for cracks, I used QBond to help the cracks, but if you powder coat it will just melt off )
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 02-27-2013 at 05:50 PM.. |
I appreciate the suggestions (meaningful and, well, less so)! I needed a couple of laughs as I was planning on driving the car to Austin tomorrow for the Grand Am race. That's out, so I'm ordering my parts so I can get started when I return.
Thanks again!
’87 Venetian Blue Coupe Last edited by ned903; 02-27-2013 at 06:16 PM.. |
Senior Member
Maybe change the sound pad, if needed?
'78 Targa in Minerva Blue |
