Wer bremst verliert
Ultra lightweight turn signal and indicator experiment?
Anyone use something like these to replace their light boxes? I was thinking about;
1. Ditching the standard light boxes 2. Welding in a tab for the lenses to screw into 3. Epoxying these in the back of the lenses for the front turn and running lights, and rear running, brake and signal lights. Seems if they are properly epoxied in place they should be weatherproof, and being LEDs are inherently vibration and heat-tolerant. Might need some resistor arrangement for the turns to work properly. Free shipping 12V SMD 12 LED Interior Room Car Bulb Lamp Free Shipping-in LED Bulbs & Tubes from Lights & Lighting on Aliexpress.com
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
Senior Advisor
yes someone did a led tail light array, looked real bright. someone did a race car application, just left the lenses in place and attached led cans behind them. that was several years ago
08 Cayenne Turbo |
Wer bremst verliert
May not be huge savings, but I'm trying to get to 850kgs so every little bit helps
![]() We moulded a long bonnet front wing in glassfibre with the light box and horn grill mounting as part of the moulding. All you need is bulb holders and lenses. |
Wer bremst verliert
I already have a carbon fiber hood and front wings. I'm trying to go lighter still...no boxes at all, just LEDs glued or clipped to the back of lenses.
Jeremy did the rears on his street track car. He has a blue IROC look blue car. Cant think of his screen name. I will try to look for the thread.
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
Rescuer of old cars
If you are wanting them for street use, bear in mind that white LEDs behind a red or amber lens will not be very bright, due to the wavelength filtering of the lens. It is recommended that the LED color match the lens color.
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
