cary's Avatar
3.0 to 3.2 Conversion JPEGS
Marcesq ........here's the JPEGS I promised.
Make sure you can get to, and secure that fuel return hose. I check it everytime I adjust the valves.
Accumulator removed from fuel supply.............
Hope this fills in the gaps for you. What are you going use for an oil cooler ? Did you find the AN lines you needed ?
Cary
77 Carrera RS w/3.2 #59
73 914S 2.0 AG
73 914 1.7 Driver ( daily driver, under complete rustoration )
74 914 2.0, 71 914 Tub, 74 914 2.0 Tub + 73 914 donor
Old 07-08-2002, 04:56 PM
marcesq's Avatar
Cary:
Your timing is unbelievable . . . see my post of minutes ago.
Can you post a pic of the hole for the DME harness.
I think I found the hose in Washington. 5.00/foot and they will install crimped -12 AN fittings on the four ends that attach to the Oil Stat, leaving 4 re-usable ends for me to attach once the hose is trimmed to fit.
Thanks . . . you are the man.
'94 CMC Firebird Trans Am
'86 951 LS1 (C-2) Gone
'77 911 3.2 (C-1) Gone but not forgotten.
http://www.pelicanparts.com/MotorCity/marcesq1
http://www.youtube.com/user/958Fan#p/u
Old 07-08-2002, 05:24 PM
cary's Avatar
Opps..........forgot one.........
Cary
73 914S 2.0 AG
Old 07-08-2002, 06:52 PM
