Architecture & Porsche's
How to do: disconnect shift handle from horiz. shift rod
About to paint my race car interior: how do these two parts separate?
Thanks!
Porsche Club Racing National Scrutineer '89 Andial 951 '82 928R '74 911 RSR 3.6 |
there is a set screw holding them together, rotate the parts to see it.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off. 2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver) |
French Import
Very similar to the set screw at the shift coupler in the back between the rear seats.
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
Ok cool guys, looks like I need a long allen key & a flashlight...& a some kneepads
If you disconnect the coupler end of the shiftrod first you will save yourself a ton of contorting and swearing. If you were happy with your coupler adjustment make sure you mark the attachment on the splined end.
The shift lever (handle) is part of the shift housing assembly. It's fairly obvious when you see it. Remove (3)-M8 and (2) M6 fasteners, then lift up on the assembly to remove from the vehicle. The lower end of the shift lever has a nylon ball bearing bush that fits into the shift lever bearing bush receptacle (the part that has the set screw). Not so obvious if you have a console in the way with all its hidden screws. ![]() ![]() Sherwood |
