Help needed removing alternator from fan housing
i've managed to remove the alternator and housing from the car, but try as much as I can, I am unable to remove the alternator from the fan housing. I've tried tapping on the bolts and heating the housing, but nothing seems to work. Am I missing something? Any help is appreciated.
’87 Venetian Blue Coupe
Old 03-24-2013, 12:53 PM
Senior Advisor
James Brown's Avatar
one of the best ways is to drop the housing rear edge on a piece of wood like a 6x6 while holding the front edge and allow the inertia to drop the alt. out, be ready to catch the alt. rotate the housing between "drops" on the wood. Don't tap on the alt nose or housing, just gentle drops should do it.
08 Cayenne Turbo
Old 03-24-2013, 01:55 PM
+1 dropping it on the wood blocks
Old 03-24-2013, 02:06 PM
steely's Avatar
+1 this is the best method.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 03-24-2013, 02:07 PM
I just did this. Drop it on two 2x4. It slips out.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 03-24-2013, 02:16 PM
Sorry to bring up an old thread.... can someone post some pics or draw a diagram to tell me how this works?
I CAN...NOT.... get my alternator out of the fan housing.
1987 Porsche 911 Carrera Coupe
Old 02-28-2018, 05:25 PM
Hold the housing with both hands, fan side down and knock the edge of the housing on a block of wood a couple of times, rotate 180 and do it again, repeat. Don't go animal and break the edge.
206 637 4071
Old 02-28-2018, 06:20 PM
Vintage Owner
Jack Stands's Avatar
And don’t hammer on the alternator bolts as they’ll mushroom out at the ends. Perhaps a small drop of oil along the studs to lubricate the dissimilar metals where they may have corroded from the dissimilar metals?
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 02-28-2018, 07:17 PM
so the idea is to bang the fan housing on both sides of some wood until the alternator slips out and fall off of it?
And this won't crack or break the fan housing??
Old 03-01-2018, 08:24 AM
Nux Nux is offline
Nux's Avatar
Put the whole thing in the oven for 10 min - it will slide right off.
Old 03-01-2018, 08:34 AM
old man neri's Avatar
Essentially. As oppose to try to bang the alternator out of the housing you are banging the housing off the alternator using it's own momentum. Get the alternator and housing moving at a speed and the suddenly stop the housing.....the alternator should keep going.
Old 03-01-2018, 08:36 AM
proporsche's Avatar
i do it as John W.said...on wood ,drop the edge of the housing ,with hand holding it and rotate. Use the weight and gravity....
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 03-01-2018, 08:56 AM
al lkosmal's Avatar
alt out
Step 1. Listen to John
Step 2. Get two 4 X 4'S (official Porsche tool # P-4x4 )
Step 3. Position the fan housing so the outside rim of the housing rests on the edge of the 4x4's (as shown)
Step 4. Hold the housing, by the sides, with both hands.
Step 5. Raise the housing off of the 4 x 4's
Step 6. Quickly lower the housing to the 4 x 4's, allowing the rim of the housing to strike the 4x4's (not too hard...let the weight of the housing/alternator do most of the work)
Step 7. If the alternator did not drop out, rotate the housing a 1/4 turn and repeat steps 5 & 6...
Note: Prior to attempting this procedure, verify that you have removed all of the associated fasteners.
RGruppe #669
http://www.x-faktory.com/
Old 03-01-2018, 09:07 AM
The 9 Store
we just use a press.
All used parts sold as is.
Old 03-01-2018, 09:18 AM
Under the radar
Trackrash's Avatar
I have to chime in here. Last year I had to remove two alternators. At any rate, I dropped and banged down both of my housings repeatedly on 4 x 6s. To the point I thought the housing would shatter. Neither budged.
The problem is corrosion around where the housing meets the lip on the alternator. I soaked that area for days then used a mallet on a block of wood covering the studs. Working carefully back and forth till the corrosive glue gave way.
I think the oven idea is worth trying, I should have though about that. Press?
Gordon
'71 911 Coupe 3,0L outlawed
Old 03-01-2018, 10:10 AM
Can't say this method ever failed me. Some are more stuck than other of course and require more effort/time.
206 637 4071
Old 03-01-2018, 03:07 PM
KNS KNS is online now
I assume the removal process is the same for the 964/993 alternator and fan..?
Kurt
Old 03-02-2018, 05:15 AM
perfect... thank you... I did this and after dropping it about 20 times from about a foot above the wood, it finally fell out.
Old 03-02-2018, 06:14 AM
thanks.. was doing this, thinking the bolts were what was holding it in.
Fortunately I took the bolts out and didn't see any damage.
Old 03-02-2018, 06:15 AM
The alternator, yes, the fan, no. Those fans are a bittch to get off the shaft. I finally made a special tool out of a large diameter steel pipe to be used in a press. I machined the inside of the pipe to allow the alternator body to enter, with some clearance and have the back edge of the fan sit on the edge of the pipe.
206 637 4071
Old 03-02-2018, 06:59 AM
