(man/dude)
I did also do an engine compartment sound blanket (lightweight style) but honestly thing the heavyweight style would block more noise. |
Can you give us more detail on the ensolite specs and any other brands we should try. I looked up ensolite and what I found looks really thick. Also what brands/specs of mlv do you suggest. |
AutoBahned
post your location, as the shipping charges for mlv may dictate where you buy it
install is easier if you do them on their own. Hang or Secure Barrier Layers (MLV/CCF) | Sound Deadener Showdown
- He gave his father "the talk" - Once while sailing around the world he found a shortcut - He taught a german shepard how to bark in spanish He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends. |
I have read all your posts and I think I need 25-40% coverage with a butyl/foil dampner and then ccf 100% and mlv 100%. Are you suggesting with the above link that I don't need to "glue" the ccf to the shelf if I glue it to the mlv? Why not just cut it to match the factory pad and reinstall it with the sheet metal tabs? Why would that be better or easier than a b-quiet type material that is ccf and mlv in one? Last edited by Ttownthomas; 04-04-2013 at 04:15 PM.. Reason: Typo |
no, you don't need to glue the ccf or mls. using don's velcro system you don't permanently adhere either to the car. they are just as effective as a floating barrier. the cld does need to go directly on to the metal to be effective.
when installing you want the seams of the mlv to overlap. when the mlv and ccf are one piece that creates an even thicker seam if you will, 1/8" thicker on every seam, thus harder to seal.
AutoBahned
IIRC, the Showdown guy is back East somewhere...
yep. the ccf is just a decoupler, the mlv is what blocks noise.
1. Will ccf and mlv fit between a 911 door card and the inner skin? 2. Why, on your audio install, did you do 100% dampner coverage on the doors if 25% will work. On Welcome to Sound Deadener Showdown | Sound Deadener Showdown this is said to be unneeded? |
1. probably not. most installs apply the ccf and the mlv to the inside of the outer door skin.
2. for audio reasons. it's called "sealing the door" but no door will ever really be sealed, you will always have the drain holes in the bottom. by covering the holes in the inner skin you form more of a chamber for the door speaker, which improves output especially on the lower end of the spectrum. it's no substitute for having a sub but it will increase your low output.
nope. i have a targa and ~85% of the time if i am in it the top is off. no amount of any product can overcome the roof missing
my approach was audio-based not trying to eliminate exterior noise. my daily driver did get the full treatment though.
AutoBahned
for the parts of the door closest to the occupants, use the heat shrink/moldable stuff by CAE
Automotive Noise Control - Soundproofing don't forget to dampen the door skin it will add wt. to your car |
Nineball offers a lot of good advice here, along with others as well. Something I've never really understood is does the sound come THROUGH the body or is it being reproduced by the car body...or both? If it's both (as I suspect) which one are we most interested in stopping or at least mitigating? I enjoy the engine noise much better when the windows are down that the noise I hear coming from the back with the windows up. I'd also like to get rid of the "tinniness" of the noise. Looks like I'll be using some of Nineballs good advice and tricks.
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
cabin noise
Why do we need CCF in the 3 step process? I already have # 1 with a foil exposed on top....can I not just put the MLV to cover it?
AutoBahned
it's both - but dampening the car body will [1] attenuate the sound from the vibrating panel, and [2] shift the frequency of the vibration to a lower freq.
the closed-cell foam isolates the MLV from the vibrating panel & dampener |
cabin noise
Thank you all for the advice....job done! results are good .../\still have a great sounding 911...but not as loud.
I still have to replace the engine compartment blanket...but worried about removing the air filter box and meter as well as the heater fan to make some working space... |
