giovanni86's Avatar
Question on WEGO III AFR
hi all,
in the next days I'm going to install a WEGO air/fuel ratio gauge. On the manual I am reading that a parameter called "RPM Pulses/Rev" and one called "RPM Debounce" must be setted.
Has anyone already gone through this? Any idea of the correct values for a porsche engine?
Thanks a lot
Bye
Giovanni
Old 04-04-2013, 01:30 PM
giovanni86's Avatar
bump
Old 04-05-2013, 12:21 PM
1986911's Avatar
I have a Wego IV.
My debounce is set to .50
My Rpm pulses are set to 3
You set it on the computer then load it to the Wego unit
Data logging interval is .60
I got this off their website. Link to pdf is very helpful too
RPM Debounce – RPM signal filtering in
milliseconds (msec). Use the default value of 0.50
msec for most applications. Ford 4.6L modular V8
engines will require a value of 3.5 msec. Suzuki
Hayabusa models will require a value of 3.0 msec.
If the RPM trace appears noisy, try a higher RPM
debounce value.
http://www.daytona-sensors.com/download/WEGO_Log_Instructions.pdf
MG---1986 911 TARGA, SSI'S, STEVE WONG CHIP, M&K EXHAUST, ELEPHANT RACING GOODIES + TRU DESIGN CUSTOM FUCHS
1989 930 FACTORY SLANT NOSE -- RARLYL8 EXHAUST, K27 7200, TIAL 46MM, 0.9 BAR SPRING, GARRETSON INTERCOOLER , LEASK WUR, WEGO IV AFM AND NHS BOOST GAUGE.
2012 DODGE RAM 3500 LONGHORN 4X4 "EVERYTHING BUT THE KITCHEN SINK"
Old 04-05-2013, 04:32 PM
giovanni86's Avatar
thanks a lot,
the manual is very good, but I thought that few hint from someone that is already using the WEGO, could be very helpful
Any other suggestions?
G.
Old 04-06-2013, 01:34 AM
Giovanni,
I used the same setting from the website. I love the Wego IV.......great AFR for the price. I have had mine for 4 years and not problems whatso ever.
Great unit.
How is it working for you? Will be glad to answer any questions. Sorry I missed your PM
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 05-28-2013, 05:14 PM
