| Registered Join Date: Jun 2003 Location: Fresno, CA
				What's difficult about removing CIS with engine in car?
			I'm doing major tuneup and vacuum leak repairs.  In the process, I've replaced all CIS fuel lines and currently have fuel lines removed as well as fuel distributor and airflow sensor. I have a '74 so no heater blower to deal with. With the airflow sensor removed, it looks to me like there is plenty of room to unbolt and lift off the CIS complete. Am I missing something? Also, besides fuel lines and throttle linkage (rod that snaps on/off), is there anything hidden that I need to undoe before unbolting and removing? I feel like it would be much easier to replace o-ring under throttle body with the CIS out and I could also replace the gaskets on the top of the engine and minimize oil leaks. In addition, I could guarantee a clean work space if I could pull off and move to a table. All advice welcome as this is my first attempt. Vern | ||
|  02-15-2013, 11:52 AM |
| Registered |
			The #6 intake runner back bolt is a pain.  Then you need to lift it up while getting your hands underneath to loosen the breather hose.  Takes some acrobatics.
				__________________ 2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab | ||
|  02-15-2013, 12:09 PM |
| Registered |
			What's difficult about removing CIS with engine in car? The obvious limiting space of the engine compartment is normally a disadvantage to removing or servicing the CIS, as compared to working on the engine on a bench, floor or work-stand.
				__________________ 78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS | ||
|  02-15-2013, 02:20 PM |
| Registered |
			I removed everything as a unit (including intake runners) fairly easily by doing a partial engine drop.
|  02-15-2013, 03:07 PM |
| Registered |
			Partial engine drop makes it easy.
				__________________ 1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera | ||
|  02-18-2013, 12:47 PM |
			When you say partial engine drop - does that mean just loosening the engine mounts and slowly lowering (i.e., not disconnecting any harness or other items that have some room to move). Also, about what distance are we talking? one thing, I've already removed the airflow sensor with fuel distributor and that (with the boot) freed up about 4-6 inches of space. Vern | ||
|  02-18-2013, 01:03 PM |
| Registered Join Date: Oct 2006 Location: MYR S.C.
			sounds like you are on your way to advising others. let us know how it goes.
				__________________ 86 930 94kmiles [_  _] RUNNING:[__] NOT RUNNING: ____77 911S widebody: SOLD 88 BMW 325is 200K+ SOLD 03 BMW 330CI 220K:: [_  _] RUNNING: [__] NOT RUNNING: 01 suburban 330K:: [_  _] RUNNING: [__] NOT RUNNING: RACE CAR:: sold | ||
|  02-19-2013, 02:20 AM |
| Registered Join Date: Jul 2003 Location: Valencia Pa.
			The fear of something falling down one of the ports while you are lifting that behemoth off the top of the motor.
				__________________ No left turn un stoned | ||
|  02-19-2013, 02:51 AM |
| 83 Targa |
			Fastfred....that is even an issue when it is on the stand.   I learned the hard way.  Take inventory on every nut and washer!
|  02-19-2013, 03:30 AM |
| Registered Join Date: Mar 2008 Location: Pittsburgh, PA
			With the rubber boots connecting the runners to the intake, you can pull each runner off the head studs and jam a shop rag into each port hole before lifting the entire unit.
|  02-19-2013, 04:14 AM |
| Registered | Quote:
|  02-19-2013, 05:52 AM |
| ROW '78 911 Targa |
			I've done it 3 times with a partial drop. My advice is to wear a long sleeve shirt and good gloves. ( Reduces blood letting) Have the car raised as high as you can to save your back. Have plenty of swivel adapters in 1/4 and 3/8 for your sockets. Have good extendable magnet positioned beside every nut and washer you remove. Don't forget the nut holding the back of the airbox to the throttle plate. | ||
|  02-19-2013, 08:06 AM |
| Registered |
				Rear sway bar........
			The rear sway bar has to be removed too. Otherwise, your transmission side would be limited to move down. I don't know your set-up. Are you using a lift or jack stands? In any case, support the engine with a solid or strong support like jackstand or wooden blocks. I try not to depend on hydraulic floor jack for this kind of work. Tony | ||
|  02-19-2013, 08:09 AM |
| Registered |
				some parts you may want to get.
			Get new gaskets and seals for: the intake runners. 91111019201 the throttle body oring: 99970112440 air box seal: 91111039402 injector sleeve:91111088603 one of my rubber mounting connetions was bad: 91111015400 these numbers are for a 1975 so verify for your car.
				__________________ 1975 911S Targa Silver Anniversary Edition | ||
|  02-19-2013, 08:41 AM |
  Did you learn the real hard way?  as in lunch a motor?  I have never done this to a p car, but I did unknowingly drop a 6 mm nut down the intake of a  ford 5.4, and kaploweee!   I had to buy the customer a motor.  That one stung a little.  Sorry to hi jack, carry on gentlemen.
|  02-19-2013, 10:51 AM |
| 83 Targa |
				intruders
 Will Hung has the right approach...cover those holes up right away! | ||
|  02-19-2013, 11:40 AM |
| Banned |
			So Tidybuoy, did you finally did it ?  Dropping the engine or not ? I'm removing CIS for leak fixing in the next few weeks so any advice is good... | ||
|  04-08-2013, 09:09 AM |
