a short, the alternator, battery or starter solenoid???
vehicle: 86 3.2L 911.
symptom: having had to start the car daily and run the engine for ten minutes or so to maintain charge to start the car; otherwise the battery goes dead. quick jump from our other vehicle will start the car (INSTANTANEOUSLY, no hesitation, no cranking/growling sound) and is good to go --unless i fail to run the engine daily. background: this battery came with the car which was bought jul 2010. battery went flat and was fully recharged three months ago; the car started fine since but the symptom is back for a couple of weeks now. i put less than 200 miles a month on the car. i want to just hook it up to a battery tender. comments/advice |
Senior Member
The amount of charge you take by starting cannot be made up for with 10 minutes of idling - you are going in reverse. The fable is that simply running the car charges the battery - true, if you are performing up to half an hour of highway driving.
You are most certainly putting strain on your electrical system, esp. the diodes in the alternator. Yes, get a Battery Tender and hook it to the battery to keep it in top nick. But first, pull the battery, go to a Local, and have them bench-test it for ability under stress. Age of battery means nothing - it is all about how it has been maintained since its first charge. Killing the alternator is a self-fulfilling thing. You don't want that kind of expense.
'78 Targa in Minerva Blue |
thanks.
In maintenance phase
I fought with a similar problem with my '69.
Annoying thing about alternators: they need power to make power. If your battery is low they the alternator won't make enough power to properly charge it back up. As a first step to solving your trouble, I would strongly recommend taking your battery out of the car and giving it a charge and load test. With the battery fully charged you may very well find that your problem goes away and that the alternator will be able to recharge the battery as quickly and efficiently as it's designed to. I had other issues, but the thing that fixed it once and for all was battery replacement. (after changing some wiring, the alternator and voltage regulator!) Good luck! -Dan
1969 911T (Getting a 72E heart transplant) 2004 Volvo XC70 Gone, but not forgotten:1971 Bug, 1978 Bus, 1982 Westy, 1996 GTi, 2000 Audi A4 2.8, 2001 Jetta Wolfsburg 1.8T, 2002 Audi allroad 2.7T, 2010 Jetta SportWagen TDi, and a couple of short lived 914s. |
Eng-o-neer
For $20, you might as well buy a few:
Battery Tender 021-0123 Battery Tender Junior 12V Battery Charger : Amazon.com : Automotive They are foolproof. |
ROW '78 911 Targa
That is a very good price, might pick up another one.
Have 2 already. |
had the battery charged up and load tested today. it passed. will buy the tender tomorrow.
i have a couple of questions on hooking up the tender. i imagine the battery needs to be isolated from the car beforehand and the tender wires clipped to the battery posts. is this correct? secondly, my house has a gas water heater and it is in the garage. should i be concerned about ventilation (in a enclosed garage) or battery gassing? can the tender be left hooked up to the battery overnight (or longer)? thanx in advance. sorry about these newbie questions but i know squat about cars and the learning curve is steep. remigio |
ROW '78 911 Targa
Battery stays connected to the car, just connect the tender clips to the terminals.
My gas furnace is in the garage, no problems, or I wouldn't be writing this! ![]() Opening the garage door once a day will provide more than enough air replacement for any hydrogen gas produced from a very active charge. Yours is a small maintenance charge and gasses very little with a maintainer. You can leave them on for months at a time as they are self regulating.
Senior Advisor
try this, with the car off, remove the negative battery cable, use a test light touch the negative terminal and touch the other end of the cable and see of the light lights. If it does, there is something that is drawing current in in the car, now comes the hard part, finding it. glove box light, hood light (make sure that that light is NOT on when doing this test) interior light, etc.
08 Cayenne Turbo |
ROW '78 911 Targa
Clock is always drawing a little. voltage can get pretty low after 2-3 weeks....
Alps Adventurer
It passed a load test, but does your battery have any capacity.
You either have an excessive electrical drain, or a battery that self drains too quickly or a battery with very little capacity. If you need a battery maintainer hooked up to the car for parked periods of less than 2 weeks, you have an issue. I can leave mine parked for a month and it'll start. |
Switch off every load in the car and connect Ampere-meter in series with battery. If there is more than 10mA current running, something is wrong and draining the battery.
Thank you for your time, |
Alps Adventurer
For example, on a 993 it is just under 50 mA and 22 mA with the immobilizer/alarm disabled. |
So 50mA is somewhat high for a car that is not frequently used.
Alps Adventurer
The only reason why I do keep the battery fully charged during the winter storage months is sulphation prevention. Its why I get the crazy number of years out of my batteries. |
RETIRED
Voltmeters draw juice as well. Most meters are on the ignition side as a result.
A tender is a good idea for our old cars if planned non op for more than a couple of days. Just my experience....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Alps Adventurer
For that reason, my voltmeter can be and is wired directly to the battery for a "true battery voltage" reading which is really what I want to know...not some voltage point in a circuit as most voltmeters are wired. |
Member 911 Anonymous
check both connectors.
I had non charging issues, found positive connecter was cracked half way down theconnector and if I moved it a bit I would get 12.8 volts to start her then I driver her around and my on board volt meter shows 11.5 BAD. No start. Replaced connector from a flaps and soldered for extra measures and $5.00 later, 14.2v at meter at speed. No more inconsistant start issues. Get the Ctek 3300 battery tender/maintainer, $60 cheap insurance.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
the battery tender i bought
i bought a deltran battery tender jr rated at 12v and 750mA. will this do? hooked it up this morning (six hours ago) and the indicator is still red. is this normal on trickle chargers/tenders or should i have gone to a higher rated tender?
by the way, thanks for all the comments and advice. much appreciated. remigio |
RETIRED
Look up the word "trickle"......nothing fast about a trickle charger. They will do a day or more before they go "red"....
You want fast, get a battery charger from sears,try to find the analog ones. The digital ones suck.
