LinkBack Thread Tools Rating: Thread Rating: 3 votes, 5.00 average.
wwest's Avatar
Originally Posted by WYDBODY1986 View Post
I have an 86 911 and I live in sunny and extremely muggy South Florida. I have done and tried pretty much all of the recommended mods to my AC to the tune of about $2000.00 over the past few years and when I pull the car out of the garage and the in car temps are around an ambient of 80-90 degrees I can get vent temps of around 35-45 degrees so I know my AC works.
The problem that I have and to some degree I am sure everyone else has is heat soaking in the Florida sun, even with the windows tinted and a sunshade in the front window if the car sits for an hour or two in the sun the interior temps are around 120 degrees easy. Given enough time the car will cool itself down and temps at the vent are 60 degrees almost immediately after I turn the AC on but even with Griffiths upgraded Evap fan motor, which is much better than stock, it still can't move enough air in the cabin to sufficiently cool down the interior in a timely manner.
What have you guys tried to move a higher volume of air in the cabin. I would rather have cool air moving at a higher volume than really cold air that I can't even feel on my face while I am driving!
First, your A/C system has no "fresh" air inlet mode, that means that in order to most QUICKLY flush the interior of the HOT atmosphere you must lower the windows slightly during the initial few driving miles and maybe even use the fresh air intake fan as an assist.
The fact that the interior surfaces are heat soaked means using the above method for a somewhat extended period, mostly as long as the temperature of the outside incoming airflow is low enough compared to the A/C "supply".
It might be of help for you to know even my '95 LS400 requires the use of the above method on occasion.
Old 05-21-2013, 05:44 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #201 (permalink)
Why do you ignore me every.single.time I ask for you to test your kit. It's amazing, and honestly a bit sad, how fervently you post on AC threads RIGHT up until someone asks for data. POOF. You're gone.
I have offered to send you the materials to test it, to find someone in your area to test it against, and yet you just stop responding to me.
You are really something, sir.
88 Carrera - Venetian Blue
2002 Audi S4 Avant (KIA)
Old 05-21-2013, 06:24 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #202 (permalink)
wwest's Avatar
Both cars that have my "kit" work perfectly fine in my environment, plus trips t/from central MT, at least one of those in 90F climate conditions.
But the Naysayers insist that the "kit" is too simple a solution, too inexpensive, to work in the HOT southern states.
Not to ignore, just cannot easily replicate the test enviroment to the level required to convince the naysayers.
Old 05-21-2013, 07:22 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #203 (permalink)
Both cars? Who has your same setup and why aren't they posting defending this setup?
What - you can't take vent temps when it's hot out? Nobody here is doing these tests in a NASA lab. Sounds to me like you know what the vent temps are going to show and you're embarrassed that they temps won't match the raging kuehl-boner that you have.
Old 05-21-2013, 07:51 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #204 (permalink)
Howdy WYDBODY1986,
I respectfully disagree a bit (smile) YOU WOULD RATHER HAVE A COLDER A/C SYSTEM WITH VENT TEMPS BELOW 40F
I think you have gotten some poor recommendations= “pretty much all of the recommended mods to my AC”
Wellpers I live in sunny and extremely muggy South Florida too, in Ft. Lauderdale (smile).
I know a bit about what the sun does in south FL to 911’s interiors and body, and when you first open the door with the windows closed before you even sit in the driver’s seat and the parked 911 sitting in the sun sometimes even before noon and the inside air temp is an honest 180 F in low humidity days before you start the engine and turn on the a/c (smile) and this is before August and September ouch.
I am an engineer and custom design and manufacture early model 911 A/C extremely cold state of the art new technology solutions
I have several new A/C inventions
i.e. this one available only for south FL 911 owners Seeking South Florida 911/930 owners interested in revolutionary A/C System invention
But that particular invention might not be within your budget, however I have others that have lower costs related to my PFC 911 custom made heat exchangers.
Regardless you do not specifically say what you did and included in your $2000.00 expenditure a/c improvements over the past few years expenditure, and a/c technology has greatly changed in the past few years; for all I know you are still running your stock oem front and rear tube and fin condensers ?
No offense but I have a feeling from the vent and ambient temps you posted you need better/newer technology condensers than you have so you had lower vent temps then you posted
FYI your condensers are the real key over evaporators for colder vent temps and comfort on early 911s
BTW Once your a/c vent temps can go/drop BELOW 45 F regardless of humidity @ 95 plus ambient, it’s a game changer EVEN using the OEM original a/c blower
I see this all the time, people mindset thinking blowers and fans is the answer when the real answer was their a/c system needed to get colder then it is;; then after they chase this fan/blower mindset route they may think they notice a degree or two improvement, BUT if they would have had a few degrees colder a/c system they would have been very cold with their original blower fan set on its lowest speed.
Now for those reading this and possibly doubting or want to dispute what I just typed, my old 1992 Geo Storm that is a wagon back (station wagon) body style has far more window area and includes a rear opening hatch than a 911 has and excellent a/c blowers with its oem stock a/c system running R-12 and always gets vent temps of 45F even @ 95 F ambient.
Old 05-21-2013, 11:43 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #205 (permalink)
Porsche Crest Know the truth about wwest
**** off, wwest. You're system is totally unproven and you refuse to post any evidence that it works. You might as well state that your AC is powered by super-cooled unicorn farts, because that's just as likely to exist as the validation of your setup.
Originally Posted by wwest View Post
Most everyone is well aware, and the EPA acknowledges, the conversion to R-134a results in lower cooling capacity vs R-12. There are other VALID reasons for converting to R-134a.
According to the SAE and the EPA, coversion to barrier hoses is not necessary, nor a requirement with R-12, nor upon converting a legacy R-12 system to R-134a.
Op was was not asking specifically about reliability, although that is a "given".
What a CROCK of clueless BS and STUPID!
ROFL ROFL ROFL at this absolute pure ignorance and stupidity from this A/C thread troll
Old 05-22-2013, 12:19 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #206 (permalink)
kuehl's Avatar
Not to ignore, just cannot easily replicate the test enviroment(sp) to the level required to convince the naysayers.
Wwest, wrinklepants apparently offered to provide you with equipment
and you recall the several posts you made about your theory of engine heat causing the ac system to "over pressurize", and how to do the simple test to see if the engine heat raises the system pressure when the car is off:
1) Drive the car hard for a period of time (lets say until the oil temp is mid way) with the ac on, lets say in any ambient temp above 70F.
2) Stop the car, turn off engine.
3) Connect your AC gauges, put deck lid down,
if you wish to cover the openings around the lid (to insure that heat rising
from the engine is absorbed by the condenser and the refrigerant gas expansion
over pressurizes the system beyond is normal operating pressures),
4) Watch the gauges. Document your observations, and report back to the forum:
a) the high side pressure when you connected your gauges,
b) how high the pressure rose on the high side if any,
c) how long it took for the high side and low side to equalize.
Connecting a set of gauges seems to be a rather simple task according to many of your peers on the board, DIY's included.
Frankly its not a matter of replicating anything, nor is it a matter of having a unique
or controlled test. Rather it is a simple observation.
You have noted in past posts that you never connected a set of gauges to your 911.
Maybe this would be a good time, before the AC season heats up. An opportunity for you to check your system to insure everything is operating correctly. Just like checking your tire pressures, oil level, air cleaner, etc.
I would imagine that since you have been posting your theory for some time now that many forum members here are curious as well. I guess we could start (author) a new thread, say something like "Test Your AC System Before the Season", and provide the steps. Maybe you'd like to take on that task? Naturally I'm curious as well, never mind that I have yet to observe your theory, but just curious.
I'll give you some time to think about it. I guess we can assume that if you don't take on the challenge shortly you would not feel offended if the "Pre-Season AC Checkup" was posted.
Old 05-22-2013, 03:26 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #207 (permalink)
wwest's Avatar
WWEST theories...Chronologically...
1.) The factory system requires additional refrigerant cooling capacity, or improved efficiency of existing capacity, in order to provide "reasonably" adequate cabin A/C cooling on a hot August day in Houston Texas. Engine lid fans or fender mounted condensor/fan put forth as a suggested solution.
2.) Adding a hi/lo pressure switch would prevent system over-pressures that might be the cause of non-barrier hose leakage.
3.) Adding a trinary pressure sensor with the extra element controllling the additional refrigerant cooling capability might abate the non-barrier hose leakage problem.
4.) Having an "after-run" capability to enable any condensor cooling capacity (front lip blower?) might absolve the leakage problem.
"1" Accepted, seemingly, by the community at large for non-Texas-like August climates.
"2" Hi/lo pressure sensor PREVENTS system over-pressures resulting from compressor cycling. Verified by Kuehl.
"3" "Might.." No dispute within the community at large.
"4" "Might.." No dispute within the community at large.
Old 05-22-2013, 06:54 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #208 (permalink)
wwest's Avatar
Kuehl: Would it suffice, really, to insert a probe thermometer into the engine lid condensor fins and watch the result post engine shutdown in the proscribed conditions.
I purchased a guage set by haven't had the need to use them yet...
Old 05-22-2013, 06:58 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #209 (permalink)
kuehl's Avatar
Kuehl: Would it suffice, really, to insert a probe thermometer into the engine lid condensor fins and watch the result post engine shutdown in the proscribed conditions. .
NOPE!
We all know the engine is hotter than "OAT" (outside air temps).
Your question is the heat from the motor turned off great enough to cause your theories:
"Theory1 " - the radiant and convention heat from the motor
could cause the refrigerant psi to rise above the operating pressures
the system has when it is operational; excessive refrigerant pressures
above normal cause "something" to leak when the system is turned off.
"Theory2 " - the low side and high side pressures takes a very long
time to equalize with a frozen evaporator or an evaporator with a core
temp below 32F.
For this you could simply unplug the compressor
clutch from its power wire by the oil filter and run a hot wire from
the fuse post on the LH side engine's power panel and just let the compressor
operate until the evap is below 32F and then turn off the motor. Have
your thermometer inserted in the evap core; you can either remove your
thermostat's sensor tube or drill a hole in the top of the box adjacent to it
you have to get your thermometer's sensitive point at least 2 inches into
the evap core, so figure distance between the top of the evap box and
the top of stock evap core is about 1" min.
At this juncture you don't need a electronic refrigerant sniffer, you just
need to observe pressures after the engine turns off
Old 05-22-2013, 07:16 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #210 (permalink)
DCinVA's Avatar
Gosh guys.
Lets stop the pissing contest.
I think everyone following these AC threads has judged the value of your opinions.
Please stop.
I think we all have respect for your knowledge and opinions, suggest you both show a little respect for each other, and the readers of this forum.
I would jump in and offer my opinion on the posters question, but no one would read it because of all the bickering going on.
Dave
2014 Cayman S (Awesome car!)
1991 911 Carerra (Semi Refined fun)
1986 911 Carrerra (Raw fun) sold
2001 Boxster S (Refined fun) sold
Old 05-22-2013, 07:33 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #211 (permalink)
1. Wwest is actually a female
2. The blue sky isn't actually blue.
3. My feet currently stink
4. Kuehl is cool. Can't think of a double entendre for Wwest.
So - since I don't see anyone taking the time out of their day to respond to my idiotic and incessant posting about all this - I can only assume this stuff is true. I mean, people give such large fvks about what I do that, clearly, people would be taking the time out of their day to prove me wrong - if I was indeed wrong.
This is one of the basic tenants of science, people! You know all that **** about having a theory, testing, and validating that theory so it becomes fact? Yeah - total BS. The right way to do it is propose ideas, wait for people to do the work proving you wrong, deflecting on proof points to make it seem like you know stuff, and if they don't prove you wrong in a way that makes you happy, then by default, you must be right.
Wwest has theories that are not rooted in engineering practices. He doesn't test, validate, or share any of his data. I have yet to hear of anyone that lives in a remotely hot climate that runs his same setup. Wwest does not live in a notoriously hot climate. These are all facts and any rational person that puts this info together would come to the conclusion that you either don't have any idea what you're talking about, you're not intelligent enough to understand test results, or you lack some type of validation in your personal life, and you get something out of all these posts that you're not getting elsewhere.
As a man - I feel embarrassed for you. You remind me of this guy I work with in the military that never went to college (maybe you did), but gets a lot of info from books. He's really into his faith (nothing wrong with that), and loves having discussions with my about evolution vs creationism. *Every one* of these conversations is him throwing out unrelated ideas that prove evolution doesn't exist and every time I counter with knowledge you'd learn in HS science class, he deflects to something else. His argument about radioactive decay is "were you around to see it go through the whole decay process?" No. "Then how do you know that's how it decays?" I mean - for someone that barely graduated HS, never went to college, doesn't put much faith in science, and has an agenda that he's trying to validate - how in the world do you rationalize radioactive decay to this person? When I see you debate with Kuehl - this is the frustration I feel because you always deflect, ignore, change the subject, or just stop posting when things go over your head or you realize you're wrong.
Prove your point with data - or Shut.the.****.up. If you haven't figured it out from reading all these AC threads, nobody cares about what you're saying, and in truth, it looks a bit sad because it seems you enjoy the negative attention. Nobody respects you for what you're doing. Nobody is doing any of your suggestions. Kuehl runs an actual business, contributes here, and throws down a lot of knowledge that he doesn't need to. You're time spent here has benefited NOBODY. Is that the kind of contribution you're trying to make to this community?
Old 05-22-2013, 07:34 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #212 (permalink)
Gee, last Summer I drove my 85 Carrera to Salt Lake City in 105 degree temps. We took long drives, stopped and shut off the engine. Take a 15 to 20 minute break to gas up and relieve the bladder. Fire up the car and drive off and have cold air in short order. I did the same thing the year before in Savannah GA, I did the same thing the year before that and the year before that. I will do it again this year.
I have not had to add one ounce of refrigerant in many years.
I have Griffith's system, barrier hoses, two fender condensers and the stock front and rear condensers. I have the Griffith's evaporator. I will upgrade to the bigger blower eventually, but the stock blower with cold air is enough for now.
With no doubt the AC upgrade is the best upgrade I have done to my 911. Before the AC upgrade I was reluctant to drive my 911 in the HOT summer months. Last year Oklahoma had the temps that made Texas look cool.
I like proven simple solutions. No smoke and mirrors. I have no desire to modify the front bumper to fit a huge condenser or radiatior in there.
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #213 (permalink)
wwest's Avatar
Originally Posted by kuehl View Post
NOPE!
Oh, I see ("said the goose..."). You're not questioning that the rear lid condensor temperature and pressure would rise post HOT engine shutdown, you're questioning if it rises high enough to be beyond the design specifications of the non-barrier hoses.
You have already verified that with an R-134a conversion and with no hi/lo pressure switch controlling the compressor the system pressure, in operation, might well rise beyond 350-450 PSI. So should I assume you need to have me see pressures beyond that level in order to verify my THEORY..??
temp below 32F.
I think I have long since verified, posted, that the low side pressure remains stable, depressed, in the conditions put forth, for more time then I had patence waiting for. I waited, watched, the low side pressure guage long enough to be satisfied that my theory was well founded.
Old 05-22-2013, 07:48 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #214 (permalink)
wwest's Avatar
No one, insofar as I am aware, has taken a position indicating that the new barrier hoses do not prevent the leakage known to exist with non-barrier hoses but only in the Porsche air-cooled engine environment.
Old 05-22-2013, 08:04 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #215 (permalink)
wwest's Avatar
6 weeks into the tenth grade (Humes) I joined the USAF, never looked back.
http://seti.sentry.net/archive/bioastro/2003/Feb/0293.html
Old 05-22-2013, 08:07 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #216 (permalink)
wwest's Avatar
Worth reading:
'87 911 A/C Upgrade - "Progress"
Even better:
Let the AC fun begin....oh to blow 45!!!
Old 05-22-2013, 08:26 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #217 (permalink)
Is this the same setup you have? A modified tail to accept a giant condensor, Rennair procooler, barrier hoses, two huge fans, and a bunch of custom connections?
Old 05-22-2013, 09:02 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #218 (permalink)
wwest's Avatar
History....
Originally Posted by Jim Sims View Post
"Only when needed. Like at idle, stop and go or rising pressure...."
Then you likely want a trinary pressure switch.
"At WOT, they and the compressor should cut out."
You will want to do this with a separate WOT cutout switch.
"Also maybe when on the brakes???? I have no decel valve anymore..."
Don't follow your reasoning here - are you trying to prevent "clutch in/throttle at idle" engine stall when braking?
"I like delaying the start of the fans when you turn on the A/C.
There will be a delay (when using a trinary pressure switch); length of delay will depend upon system temperature, air temperature and air flow over the condenser from the engine fan and aerodynamic effects.
"Is there any value to having afterrun. I.e., running them after clutch cutoff? Like an afterrun coolant pump?"
Only if the clutch cutoff was due to excessive discharge pressure; the trinary switches have a dead-band on the intermediate pressure contact function.
"How fast does high side pressure drop when the compressor stops? Seconds or minutes??"
Never ever timed it (I recall it being more than a few seconds though). It will depend on what the expansion valve is doing (how cold is the evaporator and is air blowing through it) and the temperature of the high side refrigerant.
"What about location? I may have room right off the -6 out of the condenser up in the tail."
Somewhere before the first condenser inlet not at the outlet.
"Stock driers have a cutoff at the drier???"
Some do, but it is usually just a high/low pressure cutout.
Old 05-22-2013, 09:18 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #219 (permalink)
wwest's Avatar
More...
Originally Posted by tsuter View Post
Yes, one condesnser only. I never had a front mount condenser. The new single condenser is tail mount, very efficient and big. Anyone running a turbo tail on a NA car should consider this setup.
The high end evaporator, trinary switched low profile fans, and ProCooler complete the components. I may have gone overkilll with the big compressor but it did not effect the overall cost.
Go with the best components, minimum plumbing, O-Rings, R134a. Keep it simple.
In fact I believe that if I could put a single high efficiency condenser w fans under a stock rear decklid it would get near if not the same results.
I do need a hot day. 93F on Monday was not hot enough. Really need a nice 105-110 day south Texas day!!
There's been some "woop woop" about dumping hot air into the engine bay area, but the fact is that Ferdinand himself designed all the 911 A/C systems to fully block the rear decklid entry to the engine bay with either condensers or intercoolers or both.
It was only when they could not get good performance did they begin to add more plumbing and front mounts etc.
Old 05-22-2013, 09:20 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #220 (permalink)
