So wwest claims you can walk up to a car that was run the prior day, hook up a set of manifold gauges, and the pressure on the high side will still be as high as the prior day?
The high side is isolated? |
once the compressor turns off, no matter what the temp of the condensor is doing, the pressures start to drop. and even if engine heat transfered into the condensor, it is not enough heat to raise the pressure higher than what it was when the compressor was running. even at 235psi, it would have to reach a temp of 150 degrees. i dont see that happnin dude. even on a 930 which has WAY more heat rising than a 911. |
Okay, test conditions/configuation...inconclusive fior Texans.
88 Carrera, rear lid condensor cooling fans removed, front condensor fan put back to operational status and confirmed to be operational. Digital temperature probes inserted into the rear lid condensor vanes, one at the center and the other close to the compressor high side condensor inlet. Pressure guages hooked up. 57.7F OAT. Cabin closed up, MAX cooling, lowest blower speed. Ran the engine at 2000 RPM until the compressor began cycling, indicating that the evaporator was now fully cold soaked. Dropped the engine to idle and waited for the compressor to cycle on again and then checked /recorded readings. Both temperature probes stabilized at 120F, guages at 20 PSI and 150 PSI. Compressor cycled off and then I immediately shut down the engine. Within a minute the high side pressure went from 150 PSI to 225 PSI and in less than 2 minutes to 250 PSI., and then began to fall fairly rapidly, down to 75 PSI both. No change on the low side for ~2 minutes at which time it began to slowly climb. Meantime the temperature probes slowly rose to 155F within about 5 minutes, and did not recede until I opened the engine lid at about 10 minutes. Yes, OAT at only 57.7F so not exactly a valid test in comparison to 110F in TX, and/or post a HARD engine run, but most certainly proves my point. |
http://forums.pelicanparts.com/porsche-911-technical-forum/755318-first-project-thread-88-cab-c-retrofit-cheap-2.html |
It doesnt matter where you are located. just wait until its 80 degrees outside.
Either the pressure would rise... or not. Get out your guages and do a 30 second test. What is the harm. Its your theory. You could have PROVED your theory 1000 times in the amount of time you rant on here trying to convince people with no data or proof. Post a video. Quote:
post a video. put the naysayers out of business. whats the harm. Have only been asked a few 100 times in 30 threads.
There is already a proving video...post # 22 http://forums.pelicanparts.com/porsche-911-technical-forum/755318-first-project-thread-88-cab-c-retrofit-cheap-2.html |
I read it. Anyone can make up bunk when pressed. Did you not read? I said post a video showing the rise to levels as you indicate.
there is no video doing what you state. There is a still photo that could be from any point in time. You run your own test, your own video. Come on. Whats the harm...
be a real scientists and do it right. Get out your guages, run your car till hot, and show us your test.... Not an old fart, jacking off at your keyboard using pictures on someone elses post. Quote:
Lol. TROLL!
The only possible improvement I can think of would be if you could get a politician to review your results and certify them here. That would be truly unimpeachable proof, much better than a video, which can be so easily digitally altered by any garden-variety 73-year-old. |
maybe he can hire this one. then he can have both an attorney and a politician all in one. LOL
<iframe width="640" height="360" src="http://www.youtube.com/embed/VBe_guezGGc?feature=player_detailpage" frameborder="0" allowfullscreen></iframe> or maybe this one... LOL <iframe width="640" height="360" src="http://www.youtube.com/embed/BxeFMHyOx3I?feature=player_detailpage" frameborder="0" allowfullscreen></iframe> Quote:
Since the "T" in the PV=nRT equation is absolute (in Kelvin), a jump in OAT from, say 70 degrees (294K) to 100 degrees (310K) is a little more than 5% increase in temperature. So the pressure would, in an ideal gas, jump a little more than 5% in pressure in a closed system. If the temperature of the condenser jumped up to, oh, 200 degrees F (366K), the pressure increase would be slightly more than 20% from 70 degrees F. So, for the example where someone shuts off with a high side at 150psi, that means a 20% increase would leave us with a high side max at 180psi. Even if, running R134a, and seeing high side pressures of 250 steady-state, the 20% increase would be to 300psi. That's pretty high for steady-state operation, but as a peak pressure is well within the limits of the system. |
Exactly.
Which is why he wont post a video or any data to support his theory except for hypotheticals he creates in his own mind. even if the worst case were true, as you state, it wouldnt create a failure. except maybe in the non-barrier hoses if they were already at the failure point... Quote:
Planning a trip to MT this summer, SilberUrS6, you up to being a witness? |
There arent two naysayers. people start their posts asking you to not reply. Its 1/2 the posters in any thread.
You are seen as a TROLL. at 73 id think youd be alittle smarter than this... Quote:
| All times are GMT -8. The time now is 09:58 PM. |
