xjoegtix's Avatar
911sc spark question
Hey everyone!
I just bought a 1980 911sc it isn't getting any spark at all from the coil. I had a extra coil at my shop so I tried that and still nothing. I also checked to see if the negative and positive side was getting power on the coil and it wasn't. My question to you guys is, is it my CDI box? I checked the harness to the CDI box and its getting power on I believe prong 15 (The top middle)
Old 05-25-2013, 03:20 PM
ROW '78 911 Targa
timmy2's Avatar
Green wire working?
Old 05-25-2013, 03:47 PM
xjoegtix's Avatar
Originally Posted by timmy2 View Post
Green wire working?
I'm not around the car right now but is that the wire that gets constant power when you turn the key on?
Old 05-25-2013, 03:54 PM
schumicat's Avatar
the green wire is a coaxial wire that runs from distributor to the cd box. there are lot of threads about it which can be found with a search.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 05-25-2013, 03:57 PM
xjoegtix's Avatar
If so then yes it's getting power and the fuse for all that ( I believe fuse 22) works as well
Old 05-25-2013, 03:58 PM
T77911S's Avatar
the CD unit should have a hi pitched whine to it. if it does not, then it is definately bad. if it does, you have a 50/50 shot at it being good.
the trigger unit in the dist can also be bad along with the green wire fromt it to the CD.
i dont know why people wont say their location. someone might see that they are close and offer help, or the use of one of my 2 spare CD units.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 05-28-2013, 02:26 AM
xjoegtix's Avatar
Today I checked the green wire and its good. The CDI box makes no sound at all so I checked a few other things that the Bentley told me to and it is definitely the CDI box
Old 05-28-2013, 11:38 AM
Gary.H's Avatar
Originally Posted by xjoegtix View Post
The CDI box makes no sound at all...
CDI box should 'whine', if not then it's goosed (mine was).
'82 911 SC - Slightly modified (not nearly light enough, 1130kg on 1/4 tank !) - 964 cams 232.1 bhp
Old 06-01-2013, 04:07 AM
xjoegtix's Avatar
Thanks so much for your help. It was the CDI box. Put a new one in and she fired right up
Old 06-01-2013, 03:49 PM
