I replaced the sending unit and has the gauge serviced by hollywood gauges and it still doesnt work
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Oil Level Sender Replacement - 911 (1965-89) - 930 Turbo (1975-89)
Old 05-28-2013, 12:39 PM
Nick at Pelican Parts's Avatar
You need to verify the gauge is getting electrical power. You should start by checking for voltage at the sending unit unplugged with a digital multimeter then load it with a grounded test light and see if the gauge moves. The most basic test is unplug the gauge and the needle should move all the way in one direction and then ground the sending unit wire and the needle should move all the way in the other direction.
- Nick
