Guest
Posts: n/a
how do i remove the o2 sensor from the catalytic convertor?
1988 carerra __________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Replacing your Catalytic Converter - 911 (1980-89) - 930 Turbo (1980-89) |
Remove the left rear wheel and the exhaust shield. You will see the O2 sensor in the exhaust manifold. Use a 22mm wrench to unscrew the O2 sensor.
- Nick |
Or a slotted O2 sensor socket.
Ron '88 Coupe (formerly) |
Banned
Recreational User
hit it with a BFH.
Kroil
1988 Carrera Coupe |
Eva
'78 SC Targa ~Brynhild~ Insta: @911saucy "The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman- |
Banned
Best to soak a few days with Kroil,..tapping it (lightly) with each penetrent application. .then have at it with something that will provide the necc'y torque. Mine popped loose easily,..the PO installed it properly!
BEST! Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
My brother and I just did mine last weekend. Removal was without fanfare. PB blaster on threads, waited 5 minutes or so, open end wrench on sensor, and a half dozen taps with a hammer on the wrench and it came free. I think mine was original from 1989, as i didnt see a replacement in any of my receipts.
As a note, I ended up getting the universal Bosch 3 wire at NAPA, which turned out to be kind of a bummer. They're wire connecting mechanism seems pretty hokey to me. Impossible to explain it. For a 911, you probably want the wire connectors and waterproof enclosure inside the engine bay, rather than by the exhaust, so you need to master the weird connectors at arms length in the engine bay. Not trivial. In the end it worked out ok... Of course, easy for me to say because my brother ended up doing the hard part of putting the connectors together! If you can find the OEM non universal type, I guess I'd recommend that. NAPA didn't stock them, even at the big distribution center in the twin cities... Good luck, Mark
1989 911 Carrera 3.2 2009 Audi A4 2.0TQA 2017 BMW X3 2007 BMW 328xi 1971 BMW R60/5 |
Combination c4 and dynamite, I just cut it with a sawzall then
Heat it up and breaker bar it out, very simple |
remove catalytic converter
Undocumented User
This thread cracked me up!! My entire exhaust system is out of my 87 Carrera and I just had to remove the O2 sensor. I used a quality penetrant then heated the snot out of the threaded receptacle on the catalytic converter. I got it out on the first try but the threads are completely toast. Any suggestions on what to do next? THANKS!
Northeast Ohio 1987 Porsche 911 Targa 1966 VW Beetle, 6V |
I like the "BFH" approach.
'87 911 Carrera Coupe (go fast, small parts / small kids hauler) '04 Toyota Land Cruiser (go slow, go anywhere, haul everything, the "AntiPrius") |
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Cool. Thanks!!
