grateful user
don gilbert's Avatar
A lot of people disable the system by pulling the relay, a bad no-no, renders the Freq. valve inop, which creates a lean situation at wot, esp. if control press a little high. Most have been inop for so long, when you get the freq. valve working again, it does feel like 20 hp.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do.
Old 06-09-2013, 05:20 AM
Peter Zimmermann's Avatar
Originally Posted by Nickshu View Post
My meter has only two wires, one green (to the plug) and one black to ground.
I have searched Ebay and the like for a three wire version but cannot find one. I asked my local FLAPS if they rent them but they don't even carry them at all.
I was able to set the mixture as Peter Z recommended. Set to 0.7% CO with the O2 sensor disconnected using my CO meter. Then when it was reconnected mixture was 1.2% CO. Seems to run fine at that.
Any leads on a three wire dwell meter...where to find one?
Good move. RoW SCs (w/o cat) have a slightly richer spec (1.0-2.0% CO) that is set with the smog pump disconnected. 1981> models run at optimum at the low end of the spec range, so you can actually tweak your mixture up to 1.0% if you choose. Yes, with SSIs measure out the tailpipe, and remember to always turn your adjustment screw toward rich (clockwise) before trying to make the engine leaner. Also, after an adjustment, always remove the adjustment tool, and rev the engine a bit, then let it settle at idle before taking your CO% reading.
Keep the Shiny Side UP!
Pete Z.
Old 06-09-2013, 07:24 AM
mca mca is offline
mca's Avatar
Holy cow. I can't believe this. Mine won't run without the relay. I remember when it failed - went super lean, backfired, and died.
82 911SC Coupe Chiffon / Chocolate
9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD)
Old 06-09-2013, 12:05 PM
mca mca is offline
mca's Avatar
I wanted to apologize to Nickshu and the rest of you guys for bringing up the "no oxygen sensor" issue. It wasn't my intention to go off topic like that. We can save that conversation for another time and place.
Nickshu, after you get everything sorted out would you mind logging some CO data while you are driving? I'm curious to see what kind of numbers you get while cruising and at WOT. It can be tricky keeping the sensor in the tailpipe though - I used painter's tape to keep the wire secured along the side of my car and down through my sunroof (also keeps sensor from hitting pavement if it falls out).
Thanks! Craig
Old 06-09-2013, 12:14 PM
grateful user
If you mess with it, you can get it to run fairly well with out the relay, but as i said, you have no throttle enrichment after the 35 degree throttle switch.
Old 06-09-2013, 03:31 PM
Recreational Mechanic
Nickshu's Avatar
I'm not sure if I can drive it with my Gunson gastester CO meter in the car. Don't think the hoses are long enough. If I had a dyno it would work...but I don't. I can't find the thread with the dyno data with O2 sensor unplugged vs plugged on a Lambda CIS car. It was in a recent post but the thread was not about CIS, it was about dyno and HP figures and the member mentioned it as an aside....
After reading Peter's post I want to go richen it to 1.0% with the O2 unplugged, then plug it back in.
I'll wait for my Sears engine analyzer Ebay special to arrive (thanks Psalt!) and check the dwell swing first.
Thx all!!
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches
PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing
Old 06-09-2013, 06:10 PM
grateful user
you can buy a dwell meter at radio shack, auto zone for 20bucks.
Old 06-10-2013, 03:54 AM
Nickshu's Avatar
Just make sure that it's a three wire meter.... Red and black to power and ground, green to the test plug lead. As psalt pointed out, many have had trouble with a standard two wire dwell meter not working properly, myself included.
Old 06-10-2013, 04:00 AM
