Electrical problem - tail light cluster
Rebuilding the left tail light cluster. The PO tore up left turn signal bulb socket and I just repaired it and replaced the backplate at the bottom of that socket that the bulb makes contact with to complete that circuit.
Anyhow, prior to repairing the bad socket, I had the lights working (parking, brake, reverse, etc). Only the turn signal was not working.
Now, when I switch on the lights with key in ignition turned to "2" position, all the lights in the cluster are on simultaneously. Any ideas? I haven't yet scrubbed all the fuses.
Btw, this '76 911S has sat idle for 13 years.
Old 06-12-2013, 05:49 AM
Otto H. Wegkamp
Guest
Posts: n/a
If all the light are on, but less bright, than a ground problem might be the cause. You have repaired the turn signal socket. Could it be that you forgot the ground wire or could the ground wire be broken?
Otto
Old 06-12-2013, 03:01 PM
Took the right side apart yesterday to get the correct connections. Found my error. Everything woking perfectly now!
One step closer to the road!
1976 911S, sleeping for 13 years, back to life in 2013!
Old 06-17-2013, 04:36 AM
