-   -   R-12 to R-134a parts. (http://forums.pelicanparts.com/porsche-911-technical-forum/756307-r-12-r-134a-parts.html)
brads911sc 06-20-2013 11:29 AM
Exactly.
One theory at a time. Shoot the video... or SHUT UP! otherwise most will defer to the experts..
Originally Posted by SilberUrS6 (Post 7508425)
Kuehl states the TEV doesn't close. He's the professional here.
The only professional. wwest claiming it closes? Since his knowledge of the subject is suspect (obviously, from his writings) and his hypotheses require conditions that do not exist on these cars, I would suggest that burden of proof on this subject lies completely on wwest. When weighing evidence, one must look to the credibility of the person who is presenting the evidence as to how much weight that evidence is given. An AC professional? Or some guy on the internet? Reasonable people make the best choice most of the time. I consider myself reasonable, and I will take Kuehl's word over wwest's.
Unless wwest has documentation or photographic/video evidence of the part in question. Our cars have compressors that are thermostatically controlled. Therefore, a full-closed TEV is not necessary to protect the compressor from liquid slugging. And, IIRC, compressors don't do well if the low side gets close to vacuum. It's bad for them. So having the valve open at all times prevents a low-side pressure that's too low.
Bob Kontak 06-20-2013 11:29 AM
Originally Posted by wwest (Post 7508349)
Kuehl's dessertation
Spell check is free, FYI.
Me thinks you just have fun pissing people off.
brads911sc 06-20-2013 11:30 AM
Shoot your video and prove otherwise WWEST!
Originally Posted by kuehl (Post 7508440)
Seldom ever happens if 'ever' in a 911 or 930 because of the volume between the the expansion valve outlet the compressor inlet is so large; you have the evaporator and then 12 feet of #10 hose.
The expansion valve 'type' used in the 911/930 never closes all the way! :cool:
So, when a compressor is turned off the reed valves close and high side pressure does not migrate back to the TEV,
the system equalizes because the TEV does not completely close.
brads911sc 06-20-2013 11:31 AM
he is like a pesky gnat at a picnic.
Bob Kontak 06-20-2013 11:34 AM
He never ever will. There is a disorder in play here.
kuehl 06-20-2013 11:35 AM
http://forums.pelicanparts.com/uploa...1371756882.jpg
kuehl 06-20-2013 11:36 AM
He meant to say Kuehl's Dessert.
But, think! All these AC threads are getting so many hits and posts!
Thank you Wwest. I don't have to SEO work anymore!
Bob Kontak 06-20-2013 11:45 AM
Oh hell yes on the hits. Mo Money! Mo Money! Mo Money!
You must be singing "Damn, it feels good to be a Gangsta" lately
wwest 06-20-2013 12:16 PM
Originally Posted by brads911sc (Post 7508372)
what question are you trying to answer?
What theory are you trying to prove?
You seem to be all over the board. changing the subject constantly to shift the argument. You also have a thread where you argue to the death that these hoses dont leak...
now you are accepting as gospel that they do? which is it?
I have accepted Kuehl's statement that ALL hoses leak, most of them, by design, at a perfectly acceptable rate. The question becomes, has always been, at what pressure level does the legacy hose leakage in our Porsche's become unacceptable.
GTI, Kuehl's, statement seems to indicate that our legacy hose is designed specifically to act as a "pressure relief valve" so as to prevent an "EXTREME PRESSURE " event, EXPLOSIVE event. To this I agree.
It makes no sense, obviously, for our hoses to bleed off at low system pressures, only as pressures approach a design limit specification.
I used my garden "soaker" hose only as an example that this can be done. At 2-3 PSI it only "sweats", but at 30 PSI a LOT of water permeates through the hose.
why dont you test the hoses to see if they do? how hard would that be? rig up a video and test it.
The "proper" test procedure, the one used by DuPont, involved a closed chamber with the "test" hoses inside pressurized with the subject refrigerant. A gas sniffer was then used to measure the level of refrigerant over time within the chamber due to hose leakage.
or are you now on the Kuehl wagon and are now going to change your hoses as he recommends?
The way I see it the GTI statement, possibly written/composed by Kuehl himself, fully validates my theory...our legacy hoses do not leak beyond an acceptable rate, 5-10 years, absent pressure excursions in the range of 350-450 PSI.
Whatever fits your argument of the day is the position you take. For two years you have said they dont leak. stating that Kuel is selling snake oil for saying they do. now you are agreeing with him, saying they do in fact leak.
Kuehl holds the position that ALL hoses leak to some extent, to which I fully agree.
On the more immediate theory... The increase in temp doesnt prove anything because you havent proven that the temp increase of 35 degrees = increases in pressure...
I'll just leave that to your favorite physics textbook...
Or a simple example you could use with a 9 YO, blow up a balloon inside a 78F room and then take it outside into the BRIGHT sunlight at 100F.
and what does that have to do with whether the hoses leak by design or because of the R134a molecules... what is your theory?
My theory is like that garden soaker hose design, it only leaks acceptably provided the pressure inside is appropriate to its design use....
"..the R134a molecules.." Unlike others I am perfectly willing, until evidence indicates otherwise, to accept the statements by the EPA, SAE, and Dupont, that our legacy hoses, permeated with R-12 lubricant, will only leak r134a refrigerant at a perfectly acceptable rate.
So by shooting the video and doing the tests... you will indirectly prove whether the TXV / TEV is closed ... or not...which will allow you to test whether the pressure increase leads to pressures high enough to cause leakage? which will allow you you know whether a spal fan with a trinary switch will impact the underlying problem of refrigerant loss?
and whether that leakage is in fact through hose design or some other mechanism?
Wait..you're no longer taking Kuehl's, GTI's, statements as gospel..? I'm perfectly willing to accept the statement on GTI's site regarding our hoses being designed as "pressure relief valves".
you are dancing... and you arent a very good dancer...
You've been listening to my wife..??
so you in fact have ALOT to prove... Wake up WWEST!
three cups of coffee and then my grand-daughter brought me a Starbucks latte...
WIDE awake.
http://forums.pelicanparts.com/suppo...leys/pint1.gif
wwest 06-20-2013 12:41 PM
Okay, so what happens with cars that do not have substantive suction side volume, how do they prevent compressor slugging in the same situation absent the TXV closing fully..?? Or is it now only air-cooled engined 911's that have TXV's that never fully close.
Sure...:rolleyes: :rolleyes: :rolleyes:
Any factual information other than your own speculation to back you up..??
I thought not....
Have ever bothered to even check, simple enough task for one of your experience and equipment "at the ready".
So, in other words the superheat setting for our TXV in certain conditions will allow CHILLING liquid refrigerant to flow downstream of the evaporator outlet but never reach the compressor inlet..?
Isn't this very same TXV used in the 944, 968, 928...??
wwest 06-20-2013 12:59 PM
Kuehl: looks like you have painted yourself into a blind corner yet again.
Borrow my saw...?
Bob Kontak 06-20-2013 01:08 PM
Originally Posted by wwest (Post 7508580)
Borrow my saw...?
Today is the first day in your life you ever heard about superheat.
You did not know of it yesterday.
You googled it like I did.
You simply get a kick out of this.
Plus you are a drug addict by your own admission. (See Starbucks above)
brads911sc 06-20-2013 01:26 PM
WWEST approach is to throw up as much S#!^ as he can and see if any of it will stick. If it doesnt work, then he goes back to google for more.
Thats why he never proves anything and just keeps changing the subject and adding more S#!^ to the equation. We come full circle. I guess now we dont need those SPAL fans and Trinary switches since we have perfectly working perferated hoses to bleed off any excess pressures.
Reminds me of a classic Jacka$$ scene...
<iframe width="640" height="360" src="http://www.youtube.com/embed/LvuPES4I-dw?feature=player_detailpage" frameborder="0" allowfullscreen></iframe>
brads911sc 06-20-2013 01:32 PM
Guess no Spal Fans or Trinary switches are needed after all. Sorry to anyone who wasted $$ on WWEST snake oil.
Bob Kontak 06-20-2013 01:39 PM
Jackass vid
I knew I should not have watched that.
wwest 06-20-2013 01:56 PM
My first use of the term "superheat" in this forum appears to have been August of 2011.
brads911sc 06-20-2013 02:02 PM
Well let me be the first to shake your hand and congratulate you for being able to use the search function.
Bob Kontak 06-20-2013 02:15 PM
A confirmed amphetamine junkie can post anything at anytime and not have a clue of what he/she is saying.
Sorry. Not buying it.
Like my pappy says - If ya can't beat 'em, join em.
brads911sc 06-20-2013 02:41 PM
You have quite a naysayer club wwest. Lol
wwest 06-20-2013 03:23 PM
Tried that balloon test I recommend yet??
