Rennch on YouTube
Where do get bulk fasteners?
Hi,
Instead of constantly running to the hardware store every time I need a nut or bolt, is there a place online to get a whole array of regular and/or stainless fasteners?
Michael O'Neal - 69 RSR Clone(ish) - The build: http://bit.ly/69porschersr 69 911S Blasphemy Build on YouTube Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/ |
McMaster Carr is excellent; also Fastenal sells bulk.
Rutager West 1977 911S Targa Chocolate Brown |
1+ on McMaster-Carr. I also use BelMetric.com.
Steve Sapere aude 1983 3.4L 911SC turbo. Sold |
The Pelican site sells hardware sets. Just search under 'hardware', they have nuts, bolts, washers ect.
So then the next question is which fasteners to get... 10 and 13 mm nuts, but how which bolts and what length? I guess you could check out the parts book to get an idea.
Neil '73 911S targa |
Banned
ROW '78 911 Targa
Grainger as well for things like aluminum crush washers, nuts, bolts etc.
Is there a recommended assortment for our cars from one of these suppliers?
Chief Head Scratcher
McMaster-Carr is great if you don't need your fasteners in yellow zinc. If you want the yellow/gold stuff, then Belmetric is the place to go. I usually keep a decent supply of m6 and m8 nuts+washers as these will cover the majority of your needs on an older Porsche.
The bolts are a little trickier to order as the factory tended to spec out lengths exactly as needed and not just in more generic "close enough" sizes.
John Morris '79 911SC |
Telephone the host and ask, they might have some frequently used kits.
I have this (which I don't believe the host sells) http://www.a u t o m o t i o n.com/wurth-metric-hardware-kit-general-bolt-nut-assortment-490pieces-for-porsche.html
1988 Carrera Coupe |
I didn't even think about our host, but they have a bunch of kits: PelicanParts.com - Garage Gadgets > Wurth Assortment Kits
I've had the same problem getting yellow zinc passivated (YZP) nuts & bolts. I managed to find a UK supplier, but unfortunately they only sell large quantities (200/500/1000). This is fine for nuts & washers where only a few sizes are required. However bolts are a different matter with such a huge array of sizes. That being said I did buy 500 M6 x 12 and 500 M6 x 16which Eagle Day describe as Porsches favourite fasteners.
www.shopfasteners.co.uk The other option I am l looking at is to buy bright zinc passivated (BZP) bolts which are readily available in small quantities and dip them in Yellow Zinc Passivating solution (Zinc Chromate?). This is easily obtained and only requires clean BZP items to be dipped - no electrodes or electroplating involved. The variables are concentration, temperature, and time -according to my research. I haven't tried it yet - are there any Pelicanites who have tried this? Final option is simply bit the bullet and buy from Porsche dealer - not that expensive for small quantities. |
Sorry that link should be
Welcome to shop4fasteners shop4fasteners.co.uk Hexagon High Tensile Setscrews - Zinc & Yellow YZP |
I buy mine at wegertseder.com They have a huge selection of nuts and bolts. Unfortunately only a german-language site.
Peter '13 981S '73 911T '05 996 4S cab, now gone '70 911S Targa, now gone |
Metric Fasteners
944 General Purpose Fastener Kit Eagleday always has an interesting collection of yellow zinc stuff
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! |
any auto parts store will sell a hardware assortment that has most of the common sizes. the one I get is available for SAE, DIN metric (euro cars) or JIS metric (asian cars). grilot's garage also sell such assortments as does pegasus racing. i bought the pep boys one and an empty grilot's metal storage case to keep them in.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off. 2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver) |
