z block alternative?
hey there. I know the correct tool for cam timing is the z block. I haven't received mine yet. I was planning on doing it this weekend. has anyone used anythingelse, or made there own?
....or a clamp-type indicator mount (on the same valve cover stud). Sherwood |
I made a couple that worked well for me. Couple bucks in scrap steel and a couple bucks in fasteners. Made two and along with a couple digital gauges made cam timing pretty easy.
John Thompson Eugene, Oregon |
Certified User
I have been meaning to buy one of those new-fangled z-block thingys for about thirty years but I still haven't quite got there!
I still get by with just clamping my mag base to the nearest inlet stud on the camshaft housing with a spring clamp like this. Just make sure it's sitting flat on the surface and clamped reasonably firm. There is very little actual load on the indicator but you obviously don't want it rocking around. ![]()
Bill 1988 Carrera - 3.6 engine with ITBs, COPs, MS3X 2024 Macan S Day job ... www.jesfab.com.au Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911, '21 Macan S |
I do something similar to Bill but instead use a 1/4" piece of steel bolted across a couple of intake studs (that gives something solid for the mag base).
