Another porsche with electrical problems
Hello everyone, before I start off, I just wanted to mention how helpful everyone in the past has been with troubleshooting my car. Anyhow, I have a 1980 911SC that appears to have a charging problem slightly different than other threads I have read. I just recently took it to a professional garage not a month ago and everything was fine including the battery. But the other day, i took it out and that red charging light turned on. Anyhow, the car will start once the battery has been externally charged, but it appears to have something between the alternator and the battery causing the problem. What are the means of testing the charging system on my car?
1980 Porsche 911SC |
Senior Advisor
a quick way is to disconnect the battery and use a volt meter or multimeter to check the static voltage, then clean and hook up one cable and using a trouble light, touch the disconnected post and the other to the disconnected cable and see if it lights up, this will tell any parasitic draw is going on. connect it all back up and, using the volt meter, note the voltage again, then start the car and note the voltage. should have 12+ volts before start and 14+ volts when the alt. is working (red light out). then we will go from there.
08 Cayenne Turbo |
I had the same issue some years ago
Changed the alternator brushes and fixed the problem
Paolo from Alps 1980 911 Targa SC 3.0 - Silver metallic 1980 Ducati Pantah 500 - Red 1989 Yamaha 500 "Tracker"
Ok everyone slight update, I did a drain test and it revealed NO DRAIN on the battery. Also, i did a simple alternator test by reading battery voltage with car off, during car running, and after. Results:
Before: 12.1 Volts During: 11.9 Volts After: 11.8-11.9 Volts So in theory, something having to do with the charging system is screwed up. What should my next steps be?
Voltage is low. Should be over 13 running. Id say you have a bad alternator. Id take it off and have it bench tested. They can also load test your battery. Getting as much tested now will help avoid just throwing money at the problem.
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. |
to my understanding, I think that the voltage is only low because i charged it off another car for a short period. Battery is 100% on everything as of last month. Any other options other than to just remove alternator and bench test. and what is bench testing?
They put it on a machine that tests it under various load levels and it takes other things like a dead cell in the battery, rpm levels, belt tension, a bad ground, etc out of the equation.. You can do this yourself with a multimeter but not as precise..
did you check your belt tension? RPM level? at 800 rpm and a loose belt you have have the same issue. Quote:
Essentially, when the car is running at standard rpms the alternator will be charging. If the alternator is charging, you should see approximately 13+ volts at the posts, that will indicate the alternator is charging the battery. If it does not while the car is at normal RPMs, you've got an alternator that isn't working properly. I had this issue that started to come up where the light came on sometimes. Battery tested fine, grounds were fine, it was all super great. Bad alternator. Easy way to do this is hook up a multimeter to the battery, look at what the voltage is without the car running. Should be 12+. Turn the car on, raise the rpms to something around 1500rpm. Voltage should be 13+. If voltage isn't 13+ there's something not right (alternator). This is not because it is a "Porsche with electrical problems" but rather, a car from 1980 that is probably the original alternator that has been run for thousands of miles and never replaced. You just end up being the lucky owner who gets to diagnose and ensure it's properly fixed.
1970 Porsche 914 1.7L, 1982 Porsche 911 SC Targa, 1977 Porsche 924, 1979 Porsche 924, 1999 Ducati 900SS |
Senior Advisor
agree
08 Cayenne Turbo |
I cant remember if 80 has the internal or external regulator but if its external you can try swapping it with someone.
I agree however that your alternator needs to be pulled. Not difficult, just a pita
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
'80 MY did have external VR, but it's possible an internal VR alternator has been installed at some point in it's lifetime as there was a Porsche technical bulletin for this.
'80 RoW 911 SC non-sunroof coupe in Guards Red It's not a Carrera.... It's a Super Carrera! |
.. may be cheaper
Ok, so minor update, after looking through the 101 projects book, it says that since my charging light doesn't turn off above 2,000 rpm, that it can be due to 4 things:
1) Regulator has failed 2) Battery Lead to alternator has been disconnected (anyone have a picture showing were connection is?) 3) Alternator internal bushings are dirty or worn 4)Alternator is bad After watching this video Auto Repair & Mechanics : How to Test a Car Voltage Regulator - YouTube I don't think that the Voltage Regulator is causing the problem because if it was the problem, the battery would show a very high charge 15+ while the car is running because the VR wouldn't be doing it's job. However I could be wrong. Next cause is a disconnected lead, anyone know where this is?
Senior Advisor
you don't have a high voltage condition verified by you. doubt the alt lead to the battery is disconnected but you have to dig in there and remove most of the fan to see. best at this point is to remove the alt. and VR and take them to a shop and have it checked out.
08 Cayenne Turbo |
Chain fence eating turbo
If you find the alternator is bad, have it rebuilt by a local rebuilder.
'80 indeed did have the external, which is actually a less expensive part than the internal. Does your fasten seatbelt light happen to come on intermittently, even if the belt is fastened? No annoying buzz alarm, just the light itself is what I mean.
Joe D L.I. NY 82 911 SC 3.0 Swartzmetalic |
What part of the country do you live? I'm sure someone nearby can come lend a hand.
'82 SC 3.0L Targa, Chiffon/Brown “It all began when I was looking around but couldn’t find the car of my dreams anywhere. So I decided to build it myself.” - Ferry Porsche |
Before you do anything, if I'm not mistaken there is a diode in the electrical circuit. If it goes bad it will give you symptoms as if you have a bad alternator. Check to make sure that isnot the case.
overheat
Will a loose belt cause an overheating issue as well as an alternator issue? My 79 924 is not recharging battery and it overheated. It seemed fine before and then when I went through it thinking it was a stuck thermostat I noticed that the belt was frayed and so loose I can just pull it off with my hands.
Car has been repaired. A while back, I had to jump another car using porsch. This caused the stator to break which then broke the the Alternator an regulator. I had it repaired at central jersey starter and alternator for about 400 which included removal and install.
| Tags |
| alternator , battery , electrical , red light , starting |
