Jacking up a 912 same as 911?
Can you jack up a 912 under the engine with a floor jack and a piece of wood/rubber like you do a 911? Is the sump strong on the 4 like the 6?
Thanks,
1972 911T/S MFI Survivor
Old 07-08-2013, 12:08 PM
Quantum Mechanic
mpetry's Avatar
Send a message via Yahoo to mpetry Send a message via Skype™ to mpetry
I'd recommend using the jack points and adapter for your floor jack, rather than using the engine and motor mounts to bear the entire weight of the car.
Mark Petry
Bainbridge Island, WA
81 SC
Old 07-08-2013, 12:15 PM
There is some quick maintenance needed by my brother before the weekend and he does not own a jack pad - hence the question.
Old 07-08-2013, 12:17 PM
kugelfischer's Avatar
The chassis is the same* (like 99.9% the same, obviously the motor mounts differ).
This image was posted up in a thread not too long ago.
X = Jack points
0 = Jack Stand Support Points
1973 Coupe
Projekt X (AKA bunch o' boxes full of parts)
Old 07-08-2013, 01:46 PM
So then the motor/sump will NOT support lifting the car to place jack stands?
Old 07-08-2013, 01:53 PM
Justin@Athens's Avatar
Send a message via AIM to Justin@Athens
The older the rubber mounts, the more likely the failure. This topic has been beaten to death. There is nothing inherently wrong with the jacking from the bottom of the case when you need to, but it is not optimal.
1990 964 C4 Coupe & 1991 964 C2 Coupe (current)
1989 911 Targa (sold)
1996 993 Cab. (sold)
1999 x2 Boxster (sold)
2006 Cayman S (my daily)
Old 07-08-2013, 02:15 PM
Sorry - I knew it was oft discussed about 911's, just wasn't sure about a 912.
Old 07-08-2013, 02:20 PM
FYI in his tool kit there should be a piece that inserts into the side jack point location. The piece is made for use with the factory scissor jack, but might could be used with the floor jack in a pinch. Nevermind, I was horribly wrong about that, the factory jack was never supposed to seperate in the manner I described. I happen to have a broken unit and never realzsed it!
Old 07-08-2013, 02:32 PM
912 Geek
For 45 years I have jacked up my '65 912 under the sump then put jack stands under the chassis and have never had a problem, but then it does have the early "solid" engine mounts, not the later rubber-dubbers...
Frank
Old 07-08-2013, 03:31 PM
