Agree with thermostat, oil cooler blockage, or mouse house first!
Current: 914/6 GT Conversion, Cayman Old: Many PCars + Formula Racecars |
dog. your IR thermometer is good?
seems like you checked everything. including the mouse nest everyone keeps bringing up. you have confirmed your thermometer is good?
poof! gone |
Dog,
Sounds like you have checked everything. A problem I have experienced in fuel delivery and radiators is a vapor lock. Are the return oil lines positioned with a low/high point where a vapor pocket can not easily be displaced/flushed? Good luck |
I had exactly the same symptoms! Issue with my SC was actually the oil pressure security valve, which was "open" all the time (should only open > 6bar). So - no normal oil flow could be established. These motors are not air-cooled, they are oil cooled.
I think there is also a temp valve (not the one controlling the 2nd circuit), which could probably fail. Good luck! |
Banned
Brando
Turbo powa! 1977 911s. it's cool |
Fleabit peanut monkey
Yep. +1
Check the video out 36 seconds in. Are you sure there is nothing on top of the oil cooler that you may not have seen by only removing the plates to the left and right of the center fan? Has Everyone seen this 3.2 Teardown?
1981 911SC Targa |
Straight shooter
Should be able to see the top of the oil cooler by removing #6 cyl plug wire.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values |
How did you do it???????
Tony |
Banned
In the first post, the OP said his car did not have an external oil cooler (just the engine mounted one) . . .
Reiver
Is the oil cooler 'clean'...if someone has overfilled the oil it can leak down and saturate the filter then allow for lots of dirt to become embedded in the fins. Just a thought.
You can get a good look from below it it's on a rack...unless you have SSI's that is. |
Do you know......
Do you know that a '77S (911) has two (2) thermostats even with a trombone cooler? We are talking about thermostats and not auxiliary or external cooler!!! Tony |
Confirm that the oil temp sending unit is the correct match the dash gauge. There are two different sending unit/gauge combos 65-76, and 77-89.
Mismatch the pair and you have incorrect readings. You most surely have the 77 dash gauge. But your engine was replaced with a 74, and unless the sending unit was swapped to the later part - you are getting bogus readings. The correct sending unit for a 77 is 911 606 112 00
Chuck Moreland - elephantracing.com - vonnen.com |
Banned
Tony, in his first post, the OP says that the car has only the engine oil cooler (no front cooler), so you are saying that he is mistaken? Yes, I know that 911s have an auxiliary thermostat if they have an auxiliary oil cooler (even the trombone).
Senior Member
What Chuck said. I have studied this post and have not heard you rate a 250 on your physical exterior temp checks. I only know this match requirement after changing both gauge and sensor in my '78 from useless bands to actual temps.
'78 Targa in Minerva Blue |
But if he is confirming the high temps with a hand held device that confirms the temps , then there is clearly a problem.
Good suggestion brought up so far, and you do seem to be going through this in a systematic through way. Will be a learning experience for us all when the culprit comes to light. Hang in there, and be careful not to do damage in the mean time. Cheers Richard |
do you have enough oil in it? dumb question, but you never know. it does not need to be full, although low could make it run hot, not sure if it would get hot as fast as you say.
it just sounds like oil is not getting to the cooler or air is not going thru it for what eevr reason.
Bland
I agree with the above post on checking your sending unit and making sure it matches your gauge.
2 other things to consider: 1. Pull a few spark plugs. Are they white? If so, you are running too lean and need to tweak your mixture. 2. In my 911 chump car, I had similar problems until I noticed that the plate in the gauge with the numbers on it was loose and so what was really 210 was actually reading 235 or more. It took looking at he temp under hard cornering to notice the gauge moving, not he needle.
06 Cayenne Turbo S and 11 Cayenne S 77 911S Wide Body GT2 WCMA race car 86 930 Slantnose - featured in Mar-Apr 2016 Classic Porsche Sold: 76 930, 90 C4 Targa, 87 944, 06 Cayenne Turbo, 73 911 ChumpCar endurance racer - featured in May-June & July-Aug 2016 Classic Porsche |
IR thermometers are tricky they have issues reading correct temps when pointed at shiny surfaces like metal oil lines the readings will not be accurate. I would use a thermocouple device to back up your readings.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
RETIRED
Where is the OP located?
I agree that the temps and AFR need to be verified. Willing to help if he is in So CA.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
