Re-using engine oil
I serviced my SC a week ago and obviously filled with new engine oil. I may have to drop the oil again shortly to fix a leaking cam cover. Is it OK to collect this oil and re-use?
Old 07-15-2013, 06:37 AM
Discseven's Avatar
I would... while making sure it doesn't get contaminated along the way.
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 07-15-2013, 06:39 AM
durn for'ner
livi's Avatar
Yes.
Markus
Resident Fluffer
Carrera '85
Old 07-15-2013, 06:41 AM
In theory yes, but I would never do it.
Can you be 100% sure there is no grit or dirt at all in your oil collection system?
I know 10 or 11 quarts of oil is expensive but I just can't see taking the risk. But that is just me and my engine.
Old 07-15-2013, 06:42 AM
Spiderman
Jesse16's Avatar
Be a good excuse to have two of those little valve things instead of drain plugs. Then you could control the discharge and put it in 1 or 4 quart clean containers. $50 to $100 worth of oil savings would buy 2 for sure.
Midnight Blue 08 Cayman S, Fun/Track
Black 12 VW-GTI, work
Mexico Blue 87 Carrera, sold, sad, not enough garage space.
Old 07-15-2013, 07:14 AM
I see nothing wrong with your plan, provided you capture the used oil in a very clean container. No big deal. Folks do it all the time.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 07-15-2013, 07:16 AM
Smoove1010
Smoove1010's Avatar
According to diagrams I've seen, oil from the tank is pulled directly into the engine. It's filtered only on the way back into the tank after making the circuit.
It's very tempting to re-use all that oil, but I can't shake the image of those tiny orifices in the piston squirters. I'd go to some pretty extreme lengths to insure that the oil I was putting back was perfectly clean.
Good luck,
GK
Old 07-15-2013, 07:25 AM
Filtration.........
I would suggest using a ladies nylon stocking to filter the used oil. If the oil has only a hundred miles or less and uncontaminated, there is no reason to dispose it. The oil has several thousand miles recommended usage before any change oil. The decision is all yours, there is no right or wrong.
Tony
Old 07-15-2013, 07:46 AM
Go-Kart Mozart
JAR0023's Avatar
How about not drain the oil in the first place? When you say cam cover I'm assuming you're talking about a lower valve cover. Lots of folks here have confirmed completing valve adjustment without draining the oil. Lift car only on one side and what oil is in the sump will flow to other side. You may have lose a little oil but not enough to complain about. Just top up once valve cover resealed. -J
86 Carrera
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken
Old 07-15-2013, 08:47 AM
AutoBahned
RWebb's Avatar
coffee filter
Old 07-15-2013, 01:12 PM
Banned
I re-use oil all the time (have for 25-30 years) - I catch it in a clean pan and then transfer it to clean bottles using a paint strainer in a funnel - never had a problem.
Old 07-15-2013, 01:26 PM
boxster03's Avatar
I sure would - best $1.99 you will ever save - until the engine blows that is
Member #750 Early911S Registry
1970 911E
I know Where Jerry S. has his NYC Garage
Yadda Yadda Yadda
Old 07-15-2013, 03:48 PM
We reuse ours...in a waste oil shop furnace.
Old 07-15-2013, 03:56 PM
When you use the lady's nylon stockings is she wearing them?
Old 07-15-2013, 04:18 PM
AutoBahned
RWebb's Avatar
reusing 1 week old engine oil will hardly "blow the engine"
you do want to make sure no grit is introduced and a coffee filter will filter out smaller particles than stockings or paint filters
Old 07-15-2013, 04:24 PM
S2GART's Avatar
I have never done it, but I would as long as the container you are using to catch the oil is absolutely clean and that you don't knock any dirt into it in the process of getting the oil out.
The "collection"
1983 911 SC Targa (1 of 1430 imported)
1994 MB E320 Coupe (1 of 825 imported)
1992 MB 190E 2.6
2004 Volvo V70 2.5 Turbo (1 of a bazillion imported)
Old 07-15-2013, 04:26 PM
Aircooled Breakfast
This is the correct answer to the OP's question. No need to drain a drop to pull a lower valve cover - just elevate that side!
Old 07-15-2013, 05:03 PM
Taking it apart is easy
Jerome74911S's Avatar
Ditto. Been there, done that.
Jerome
PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com
Old 07-15-2013, 05:29 PM
Wow! You better not reuse that oil! Your 35 year old car may not make it to 300,000 miles. Maybe only 250,000!!!! OMG!
Old 07-15-2013, 06:14 PM
Banned
I've tried using a coffee filter recently when I was out of paint strainers and I couldn't get the oil to go through it (would have taken all night for one quart to pass) - must have been using the wrong filters?
Old 07-15-2013, 06:18 PM
