Re-using engine oil
I serviced my SC a week ago and obviously filled with new engine oil. I may have to drop the oil again shortly to fix a leaking cam cover. Is it OK to collect this oil and re-use?
I would... while making sure it doesn't get contaminated along the way.
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
durn for'ner
Yes.
Markus Resident Fluffer Carrera '85 |
In theory yes, but I would never do it.
Can you be 100% sure there is no grit or dirt at all in your oil collection system? I know 10 or 11 quarts of oil is expensive but I just can't see taking the risk. But that is just me and my engine.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Spiderman
Be a good excuse to have two of those little valve things instead of drain plugs. Then you could control the discharge and put it in 1 or 4 quart clean containers. $50 to $100 worth of oil savings would buy 2 for sure.
Midnight Blue 08 Cayman S, Fun/Track Black 12 VW-GTI, work Mexico Blue 87 Carrera, sold, sad, not enough garage space. |
I see nothing wrong with your plan, provided you capture the used oil in a very clean container. No big deal. Folks do it all the time.
Christopher Mahalick 1984 911 Targa, 1974 Lotus Europa TCS 2001 BMW 530i(5spd!), Ducati 900 SS/SP 2006 Kawasaki Ninja 250, 2015 Yamaha R3 1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750 |
Smoove1010
According to diagrams I've seen, oil from the tank is pulled directly into the engine. It's filtered only on the way back into the tank after making the circuit.
It's very tempting to re-use all that oil, but I can't shake the image of those tiny orifices in the piston squirters. I'd go to some pretty extreme lengths to insure that the oil I was putting back was perfectly clean. Good luck, GK |
Filtration.........
I would suggest using a ladies nylon stocking to filter the used oil. If the oil has only a hundred miles or less and uncontaminated, there is no reason to dispose it. The oil has several thousand miles recommended usage before any change oil. The decision is all yours, there is no right or wrong.
Tony |
Go-Kart Mozart
How about not drain the oil in the first place? When you say cam cover I'm assuming you're talking about a lower valve cover. Lots of folks here have confirmed completing valve adjustment without draining the oil. Lift car only on one side and what oil is in the sump will flow to other side. You may have lose a little oil but not enough to complain about. Just top up once valve cover resealed. -J
86 Carrera Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken |
AutoBahned
coffee filter
Banned
I re-use oil all the time (have for 25-30 years) - I catch it in a clean pan and then transfer it to clean bottles using a paint strainer in a funnel - never had a problem.
I sure would - best $1.99 you will ever save - until the engine blows that is
Member #750 Early911S Registry 1970 911E I know Where Jerry S. has his NYC Garage Yadda Yadda Yadda |
We reuse ours...in a waste oil shop furnace.
When you use the lady's nylon stockings is she wearing them?
AutoBahned
reusing 1 week old engine oil will hardly "blow the engine"
you do want to make sure no grit is introduced and a coffee filter will filter out smaller particles than stockings or paint filters |
I have never done it, but I would as long as the container you are using to catch the oil is absolutely clean and that you don't knock any dirt into it in the process of getting the oil out.
The "collection" 1983 911 SC Targa (1 of 1430 imported) 1994 MB E320 Coupe (1 of 825 imported) 1992 MB 190E 2.6 2004 Volvo V70 2.5 Turbo (1 of a bazillion imported)
Aircooled Breakfast
Taking it apart is easy
Ditto. Been there, done that.
Jerome PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com |
Wow! You better not reuse that oil! Your 35 year old car may not make it to 300,000 miles. Maybe only 250,000!!!! OMG!
Banned
