First time on Jack Stands -- Placement Question
Just jacked up my targa for the first time. If you wouldn't mind, could you take a look at this picture and let me know if this placement for the jackstands is safe?:
The 101 project books says the torsen bar covers are the best place for the jackstand, so I'm less concerned with where the jackstands are vs. how the torsen bar covers are resting on them. I'm using esco jackstands, and it seems like the car is only resting on about half of the top of the stand. Is that safe? For what it's worth, I pushed the car pretty hard and it won't budge. Better safe than sorry though.
Thanks for your help!
84 Targa
Old 07-15-2013, 04:14 PM
S2GART's Avatar
That should be fine. Admittedly I have never seen jack stands like that, but if she hasn't dropped by now........ I don't quite get the design of the "cradle" of those stands. Those will work for where you have them, but I wouldn't want those used on a flat or broad surface.
The "collection"
1983 911 SC Targa (1 of 1430 imported)
1994 MB E320 Coupe (1 of 825 imported)
1992 MB 190E 2.6
2004 Volvo V70 2.5 Turbo (1 of a bazillion imported)
Old 07-15-2013, 04:32 PM
rokemester's Avatar
Like those fancy jack stands! Time to get those babies dirty
Northeast Ohio
1987 Porsche 911 Targa
1966 VW Beetle, 6V
Old 07-15-2013, 05:22 PM
schumicat's Avatar
that's the right place but I don't think it is ideal that the weight is all on one side. more typical stands (narrower top part) the weight is centered over the stand.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 07-15-2013, 05:54 PM
I vote for making this a sticky? Its the question I have always wanted to ask but never have. Whenever my car goes into a tire shop I cringe.
While we are at it, what are the best locations front and rear to support the car, and if not using the jack plates from the stock location, what are the safe points to be jacking from?
Old 07-15-2013, 05:59 PM
That's my concern. These stands are sold by our hosts (link) so I'm hoping someone else with the same stands might be able to chime in.
I'm pretty paranoid about being crushed, so I went with the best quality jack stands I could find. The best jack stand in the world is no good if it's improperly used though, which is why I'm nervous.
84 Targa
Old 07-15-2013, 06:21 PM
Yep, you got it right.
Old 07-15-2013, 06:28 PM
redstrosekNic's Avatar
I use the transmission crossmember to jack my car up. Never have had any issues...
http://forums.pelicanparts.com/Porsche-911-technical-forum/608219-transmission-crossmember.html
Dustin
Old 07-15-2013, 06:30 PM
Another +1 for using the correct location
Dustin
Old 07-15-2013, 06:31 PM
Go-Kart Mozart
JAR0023's Avatar
+1 I don't like it. If I had to use those jack stands they'd be under the torsion tubes, inside the frame rails. -J
86 Carrera
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken
Old 07-15-2013, 07:47 PM
jkevinc's Avatar
If they we're mine, and if i wanted to use them on those stubby covers, i would take a metal cut off wheel on a grider and make at least one side of the saddle narrower.
Old 07-16-2013, 08:04 PM
SoCalSK8r's Avatar
+1
Originally Posted by jkevinc View Post
if they we're mine, and if i wanted to use them on those stubby covers, i would take a metal cut off wheel on a grider and make at least one side of the saddle narrower.
Old 07-16-2013, 08:17 PM
I'm not crazy about how those stands "cradle" either. Regardless of method, if the wheels come off the car, place them underneath the tub (for example) or have a backup floor jack or something in place in case of a failure. I don't ever crawl under my car without a backup in place...be safe!
Old 07-17-2013, 03:08 AM
Smoove1010
Smoove1010's Avatar
FAIL Happens
Here's a good thread on the subject - it starts off with a reminder about why this is a topic that's not to be taken lightly.
Jack stand accident while under a Porsche....
Old 07-17-2013, 04:44 AM
Thanks for the input guys. I jacked her up last night and changed the oil for the first time. To be safe, I put the jackstands on the torsen bars inside the frame rails. Worked like a charm.
84 Targa
Old 07-19-2013, 05:43 PM
