First time on Jack Stands -- Placement Question
Just jacked up my targa for the first time. If you wouldn't mind, could you take a look at this picture and let me know if this placement for the jackstands is safe?:
![]() The 101 project books says the torsen bar covers are the best place for the jackstand, so I'm less concerned with where the jackstands are vs. how the torsen bar covers are resting on them. I'm using esco jackstands, and it seems like the car is only resting on about half of the top of the stand. Is that safe? For what it's worth, I pushed the car pretty hard and it won't budge. Better safe than sorry though. Thanks for your help!
84 Targa |
That should be fine. Admittedly I have never seen jack stands like that, but if she hasn't dropped by now........ I don't quite get the design of the "cradle" of those stands. Those will work for where you have them, but I wouldn't want those used on a flat or broad surface.
The "collection" 1983 911 SC Targa (1 of 1430 imported) 1994 MB E320 Coupe (1 of 825 imported) 1992 MB 190E 2.6 2004 Volvo V70 2.5 Turbo (1 of a bazillion imported)
Like those fancy jack stands! Time to get those babies dirty
Northeast Ohio 1987 Porsche 911 Targa 1966 VW Beetle, 6V |
that's the right place but I don't think it is ideal that the weight is all on one side. more typical stands (narrower top part) the weight is centered over the stand.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off. 2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver) |
I vote for making this a sticky? Its the question I have always wanted to ask but never have. Whenever my car goes into a tire shop I cringe.
While we are at it, what are the best locations front and rear to support the car, and if not using the jack plates from the stock location, what are the safe points to be jacking from? Thanks |
I'm pretty paranoid about being crushed, so I went with the best quality jack stands I could find. The best jack stand in the world is no good if it's improperly used though, which is why I'm nervous.
84 Targa |
Yep, you got it right.
I use the transmission crossmember to jack my car up. Never have had any issues... http://forums.pelicanparts.com/Porsche-911-technical-forum/608219-transmission-crossmember.html
Dustin |
Another +1 for using the correct location
Dustin |
Go-Kart Mozart
+1 I don't like it. If I had to use those jack stands they'd be under the torsion tubes, inside the frame rails. -J
86 Carrera Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken |
If they we're mine, and if i wanted to use them on those stubby covers, i would take a metal cut off wheel on a grider and make at least one side of the saddle narrower.
I'm not crazy about how those stands "cradle" either. Regardless of method, if the wheels come off the car, place them underneath the tub (for example) or have a backup floor jack or something in place in case of a failure. I don't ever crawl under my car without a backup in place...be safe!
Smoove1010
FAIL Happens
Here's a good thread on the subject - it starts off with a reminder about why this is a topic that's not to be taken lightly.
Jack stand accident while under a Porsche.... |
Thanks for the input guys. I jacked her up last night and changed the oil for the first time. To be safe, I put the jackstands on the torsen bars inside the frame rails. Worked like a charm.
84 Targa |
