![]() Fuuuu. Guess I'll just buy an OEM switch. Looks like the part has been updated.
Matt - 84 Carrera |
Griff's variable fan speed controller has been working well for me for the last five years.
Griffiths supplies a range of air conditioning components for your Porsche 911,911s,911t,911 turbo, and 930, such as: Porsche air conditioning upgrades, Porsche air conditioning improvements and updates: Porsche barrier hoses and hose sets, Porsche c It costs much more than $20. It is plug and play. It works, and works, and works, and works, and works, and works, and works...well, you get the picture. |
![]() FWIW, it's in with a reasonable amount of fuss. A PO had a large blue switch between the knobs that didn't do anything, but judging by a wire tap back there at one point it was to switch the AC circuit off and on. Seemed like a good idea, so I got a fresh switch and did the same. Now I can run the dash vents without AC at all if I choose. If the PWM holds up, I'll adapt the OE knob so that it'll look close to factory. I ran it for about an hour yesterday, the PWM barely got warm. I have high hopes. Also of note: My fan at full blast was drawing only about 10A, the AC circuit alone was drawing about 4A. Not bad for $25.
Matt - 84 Carrera |
I'm confused - my front condenser fan run at about 3.7A, no-where near the 7.5A or 10A talked about here and other threads. Mine works, it runs happily without getting anything hot, but I imagine it's not very effective as a condenser! Any thoughts??
tl;dr Basically it might reach 7A for the first split second then level off to 3.7A.
Matt - 84 Carrera |
I'm hoping for confirmation of the expected run current, and comparison with other blower motors run current, to see if it is worth replacing it. Thanks. Last edited by Algernon; 08-09-2013 at 11:10 AM.. |
I think the running current of the blower motor on mine was less than 5 amps, but I agree with Driven97 - the current of a starting motor can be 2 to 3 times the running current. I also used foam to seal around the front condenser to body, which would put more load on the motor.
Mike
The more I learn, the less I know. |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Front condenser blower motor current.
![]() ^^^^^ As measured on our '86.
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
