Learn me: A/C fan switch / electrical
I have no idea the last time the A/C was run in my car. When I bought it, there was either a blown fuse or no fuse in the circuit that controls the dash vent fan (can't remember.) The front condenser looks like it's been monkeyed with a bit too.
I decided to throw a charge in the system and see what happens. Well, it works. I have pretty cool air coming out of the vents. The decklid and front condensers both get quite warm. The front condenser fan next to the battery works, but is noisy. The fan works at all speeds, but the switch base feels like it gets quite warm - warm enough that I have concern. Also that front motor makes me a little nervous. Is there anything I should consider re-wiring, replacing, or improving in the circuit? Is the warm fan switch normal? Is there a modern alternative to the front condenser fan or do I have to replace with OEM?
Matt - 84 Carrera |
Driven97,
The front condenser fan needs an inline fuse to prevent melting down the wiring harness if the motor fails. ![]() cfm on the front AC condenser fan When I checked mine, the brush holder had started to melt down. A footwell blower motor can be used for the front condenser fan motor, I think BarryJB found this - it spins faster than the stock motor, and is the same dimensions as the original motor. cfm on the front AC condenser fan Mike
The more I learn, the less I know. |
Try cleaning all the contacts at the switch. Dirty contacts cause resistance increase and this in turn results in heat at the contact. It could also be that the internals of the switch are corroded from not being used, in this case you need to replace the switch.
+1 on adding the in-line fuse as mentioned above.
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
Fuse to the front condensor's blower is a great idea. Below... blower motor brushes without a fuse. The variable switches... I've found they just rot out over time.
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
Or even better yet...
12 volt 30 amp PWM DC motor controller, $20 on ebay.
Or: http://www.aliexpress.com/item/Free-shipping-5pcs-9v-28V-30A-DC-Motor-Speed-Control-PWM-HHO-RC-Controller-12V-24V/640044963.html Last edited by wwest; 07-23-2013 at 09:03 AM.. |
Ok - thanks for the replies.
I'll at least fuse the front fan, and probably swap to a relay control. In the photo is a 7.5A, but the linked thread says 10A gives more headroom for startup - so 10A? For the switch - let me know if I have this right: The OEM uses power resistors, which dissipates power as heat to slow the fan. A PWM control turns the fan on and off at a high frequency, with a variable "on" time? EDIT: How much current for the blower motor?
Matt - 84 Carrera Last edited by Driven97; 07-23-2013 at 09:31 AM.. |
Reading comprehension fail. Sometimes I wonder how I get by. Thanks for the help.
Matt - 84 Carrera |
Ty ww ~
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Front condenser fan fuse holder.
It's plug & play...... ![]() ![]() ![]() Good luck, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Driven97,
I started off with a 7.5 amp fuse based on the running current of the motor. The starting current blew the fuse, so I ended up using a 10 amp fuse. This is for a footwell blower motor. 86 911 Targa - Thanks for the fused harness part number. Mike
10A is the correct value for the footwell blowers.
I ran dedicated line from the battery yesterday, going through a relay, through a 10A fuse. Possibly overkill. My fan housing was also a bit buggered - leaves in there, housing cracked, missing clips, motor loose, squirrel cage scraping on housing, and taped together in places.
I also ordered one of those PWM controllers, I get to figure out how to wire that as soon as it comes in from China.
Matt - 84 Carrera |
My one of these showed up from China yesterday. The SOB works by modulating the ground on a common positive. That would be awesome if the car was positive earth, which it is not.
So, to use it, I either have to run dedicated lines from the PWM to the blower or swap polarity on the motor end and run a fused constant hot to the A/C blower right from the battery. Neither of those sounds like fun, and one sounds like a bad idea. Maybe I'll just buy a new OEM switch.
Matt - 84 Carrera |
Like many have said... Ignore recommendations from wwest... You just will pay twice
If it were me I'd buy the Kuehl switch so you have variable air. It's plug and play... Quote:
For posterity - if anyone else finds this thread in the future, do not buy the PWM pictured. I'll probably try and make it work since I like a challenge, but it's probably not worth it. Worst case I'll have a neat little $18 PWM I can try and invent a use for.
Matt - 84 Carrera |
We tried one, it lasted less than 12 hours running continuously at 3/4 load.
If you buy a box full of them, you should be OK. |
