Steering not smooth
Hi guys,
I tried searching but no luck. My steering is kind of hard to turn. It feels like it is not smooth and I can hear it as I turn. It seems to come from box as I can feel the tie rods kind of vibrate when I turn (it is hard to describe). It seems like there is an excessive amount of friction in the rack. Is this something that is possible? The car is a 1985 930 with almost 60k miles on the clock. I have ER front bushings. Thanks for the help David
David 1985 Black 930, K27 7006, Garretson Intercooler, Adj boost, TB: 23 - 31mm, bielstein sport shocks, ER polybronze bushings front and rear, ER monoball joints front and rear with offset camber plates, 935 X triangulated strut brace, raised spindles, racing bump steer kit 1981 Black 911sc (sold) |
RETIRED
Does the wheel wobble up and down? Steering wheel bushing, easy fix.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Pure Awesomeness
I would recommend Mitch Leland's bushing as a replacement if that is indeed what your problem is. Search for his name on here and you will find additional info.
1977 Porsche 911 |
i just pulled a rack out today that was stiff with some extra freeplay and it was full of rusty water.
That's what I am scared of... The steering column bushing is nice and tight, it kind of looks like the rack... Is there any way to lubricate it?
Thanks David
Yes, see here for an excellent guide, including replacement of bearings if you want to go the whole hog. This will require pulling the rack though.
Thanks, I will have to it that on my list
Before you take too much apart, try this simple test - disconnect the upper steering u-joint, the one just after the steering wheel shaft. Now spin the wheel and see if it's smooth. I was SURE I had a bad steering rack but my problem turned out to be a bad lower steering column bearing (bad like almost seized).
I found a way to R&R the steering column bearings without removing the column, using some bushings and pullers. HTH, Chuck.H '89 TurboLookTarga, 360k miles Last edited by Chuck.H; 07-26-2013 at 05:06 AM.. Reason: rack -> column |
There are needle bearings at the top of the steering box and in the rubber sleeve in the linkage that wear out.
Scott Wilburn 1988 911 Carrera 3.4 L 1998 M3 1984 308 QV |
