My other ride is a C-130J
RNajarian's Avatar
Recommended Air Flow over the front A/C condenser
Well the title pretty much says it all.
Is there a Porsche spec that specifies the recommended amount of air (measured in CFM) that should flow over the front A/C condenser? I am ready to install that component and wanted to know what the Fellas in Stuttgart thought.
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic
2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer
Previously Owned Art from Stuttgart
2000 Boxster -1983 911 SC Cab -1984 944 N/A
Old 07-26-2013, 12:03 AM
It is not much, that is for sure. With the AC system running that fan does not produce a lot of volume. If you put your hand under the front bumper you can feel warm air sort of oozing out. Since I have 3 other condensers I don't figurer it does a lot on my car.
Old 07-26-2013, 05:44 AM
wwest's Avatar
The factory tube and fin condenser does help a smidgen in stop and go traffic but quite a lot underway at a decent roadspeed.
The aftermarket ones seem to rely strickly on the low volume HIGH noise content of that front fan as every one of those appear to be designed to BLOCK airflow due to roadspeed.
Old 07-26-2013, 07:04 AM
brads911sc's Avatar
How could this be? If the fan helps the factory how could the fan not help the aftermarket one.
I would think that the aftermarket would be as good as the stock. I really would also be interested in putting a better fan on those units. Seems like if you could get better airflow it would be Better than a spal fan on the deck...
Old 07-26-2013, 07:16 AM
El Duderino
tirwin's Avatar
Do you have a chin spoiler? Seems like that would also make a big difference in the amount of airflow.
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 07-26-2013, 07:17 AM
Fleabit peanut monkey
Bob Kontak's Avatar
The great contributor of unsubstantiated armchair thinking, with a big twist of spite, spews non-value adding hatred again.
What a joke this guy is. Why he is not sent to the island for harassment is beyond me.
1981 911SC Targa
Old 07-26-2013, 07:25 AM
brads911sc's Avatar
I agree Bob. Pelican Must really not care about the continued assault on products they sell and endorse. Seems strange to me.
Old 07-26-2013, 07:45 AM
Bob Kontak's Avatar
Within a small handful of posts we are down the rat hole again. The OP routinely is confused and disengages. The thread dies from being valuable once wwest posts and receives push back.
No benefit to discussing the original topic as continuity is gone.
It's disgusting.
1981 911SC Targa
Old 07-26-2013, 07:57 AM
Go-Kart Mozart
JAR0023's Avatar
I measured airflow with an anemometer and made some rough calculations. I've posted the numbers before if you want to search my username. What follows is strictly from memory so I may be off.
IIRC the flow from the factory set up is only around 320 CFM. The motor from a Carrera footwell blower is almost a straight drop in and will increase flow rate to 450 CFM. You have to fiddle with the wiring hook ups but the motor physically fits. Again from memory the condenser motor spins around 3k rpm and the footwell motor closer to 5k rpm. With a footwell motor installed noise increases significantly. Not enough to hear inside the car but everyone around you will know it's on.
The factory condenser fan actually blows just enough to create a circular flow pattern. Someone else here, posted a diagram. I didn't think of it but I did come up with a redneck test for it so I could demonstrate for my daughter. The fan is set up over one end of the condenser and the plate it sits on has a slight peak. Air flows down on the driver's side and up on the passenger's side.
Go the the bathroom and grab a single square of tissue. Turn your A/C on and key to the run position so the fan is blowing. Holding the square flat in your hand try to place it flat against the condenser cage on the D/S of the car. Can't be done. Now try the same thing on the P/S of the condenser. Airflow on the P/S of the condenser will pull and hold a tissue against the bottom of the cage.
As WWest noted 911 A/C works much better at speed that when stationary. What he continues to ignore is that front condenser airflow at speed is not front to back. It's top down. WWest denigrates the design of aftermarket front condensers while ignoring the evidence that they actually work better. When the car is at speed air is flowing under the car and past the condenser. The air flowing past the condenser is pulling air through the condenser. The flow at speed is still limited by the fact that any air flowing through the condenser must be sucked in through the small hole in the front of the tub. -J
ETA - I ran a footwell blower motor last summer. The extra airflow definitely helped prevent vent temps from climbing when the car was stationary (at a stop light,etc). I'm not sure that it did a lot at speed. I eventually pulled it and went back to a regular condenser blower motor. -J
86 Carrera
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken
Old 07-26-2013, 08:01 AM
Bob Kontak's Avatar
Thanks JAR0023
I found the link.
cfm on the front AC condenser fan
1981 911SC Targa
Old 07-26-2013, 08:07 AM
Go-Kart Mozart
JAR0023's Avatar
Originally Posted by Bob Kontak View Post
Thanks JAR0023
I found the link.
Thanks, Bob. I edited my post to correct flow numbers. It's not as big a jump in flow as I remembered to move to the footwell motor. -J
86 Carrera
H. L. Mencken
Old 07-26-2013, 08:13 AM
brads911sc's Avatar
Good info. Guess we have another case where wwest is full of bs on which he has no proof other than his own dreamed up theory. Post your videos wwest. Just because the front condenser seems to do nothing at 70 degree ambient where you live doesn't mean it doesn't work at 95 degree ambients. Probably should just shut up so you don't continue to look foolish.
Old 07-26-2013, 08:17 AM
wwest's Avatar
Insofar as the fan goes the aftermarket front lip condensers probably work better than factory, but since natural airflow arising from roadspeed is quite thoroughly BLOCKED then overall they are SNAKE OIL.
Old 07-26-2013, 08:21 AM
Flat Six
Flat Six's Avatar
Most helpful A/C post I've seen here in a while; thank you JAR0023.
Dale
1985 Carrera 3.2 -- SOLD
2026 Jaguar F-Pace / 2025 Ford Bronco Sport
Followed by the most usless post in an AC thread.
Old 07-26-2013, 08:25 AM
wwest's Avatar
Bob, have you not taken a good close look at the aftermarket front lip condensers? If not then you mostly certainly should.
Once you have would you please inform all of use just how those aftermarket front lip condensers take advantage of the HIGH LEVEL of cooling airflow at, say, 70 MPH.
What is the front to back airflow path?
Old 07-26-2013, 08:26 AM
brads911sc's Avatar
But in stop and go would be more effective as a heat exchanger than the deck. At speed your spal on the deck does more harm than good as it blocks airflow. A better front condenser in stop and go would actually reduce engine temps. Think wwest think.
Old 07-26-2013, 08:31 AM
wwest's Avatar
But,,but,..but...That's EXACTLY my point, there is NO easy path for top down airflow other than that supplied through the fan inlet opening. Look at the CSA of the top/down surface of the after market condenser vs the CSA of the opening for top/down airflow. How can anyone knowing those numbers conclude that the aftermarket condensers "actually work better"...?
Yes, but only for stationary or stop and go use...
The flow at speed is still LIMITED by the fact that any air flowing through the condenser must be sucked in through the small hole in the front of the tub.
Yes..whereas the ENTIRE factory tube/fan condenser, front to back, is highly condusive, can be cooled by, roadspeed airflow... -J
Have you thought about running the cabin heater blower, perhaps even automatically, either with a trinary pressure or thermal switch?
Old 07-26-2013, 08:38 AM
Go-Kart Mozart
JAR0023's Avatar
It's amazing how myopic one's view is when they are fueled by hatred.
At speed air pressure on the front of the car added to the blower fan creates a high pressure area above the condenser.
Airflow under the car creates a low pressure area under the condenser.
Airflow is top down. The faster you go the greater the airflow.
$hit, my 10 year old knows who Bernoulli is. -J
86 Carrera
H. L. Mencken
Old 07-26-2013, 08:41 AM
Bob Kontak's Avatar
I don't profess to understand airflow. I'll leave that to guys that do.
You have a lot of value to add wwest. I'll stick to my single argument. That is, your grudge is disruptive to the overall integrity of this forum - specifically AC threads.
I do like it (a lot) when you beat on Lorenfb but he demonstrates behavior that is deserving of such. I ain't seeing that in the AC thread community as a rule.
1981 911SC Targa
Old 07-26-2013, 08:43 AM
