I don't know if someone else mentioned this - but upgrading to SC struts will allow you to install larger brakes. Your stock struts have 3" o.c. caliper bolts, the SC has 3.5" which will allow you to chose from a huge selection of brake options. With your stock struts, you're stuck with the small brakes. Now, this really isn't an issue for street driving but...
Chris '75 911s 3.2 - Ice Green Metallic 87 951, '05 987 S '21 Jeep Gladiator 18 Tesla ModelX 100D, 20 Model 3 |
Banned
OK, Rwebb and Boba, you talked me into it. I just found a place that does unibody straightening and they are not too far from here. I'll give them a call and see what they charge to check out the body.
That is probably a good idea. Maybe they can even tell me if my A arms and struts are straight. |
Banned
Under the radar
If you raise the spindles you will have to somehow correct for the bumpsteer caused by raising the steering arm either by having the arm bent or installing a bumpsteer kit. (the rack spacers won't do it) It will also change your roll stiffness, so you will have to adjust that by stiffening the rear suspension. Up to this point it is all conjecture, since we really don't know exactly what struts and calipers you have. I would first measure your wheel base on each side and see if there really is a 1" difference. Then jack up the car, take off the wheel and measure the spacing of the caliper mounts, it's either 3 or 3.5". Also the struts should have the manufacture and date stamped near the top. While you are in there make sure the gland nut is tight. I bet the alignment guy never checked. Have you had any tire wear problems?
Banned
I just measured cap to cap. I had my wife eyeball the middle of the cap and I held the other end. The caps are recessed so it is not exact, but it looks like 89 1/4" on the passenger side and 89 1/2" on the drivers. That's weird?
Under the radar
Here is a shot of the struts I have on my car now. They are Konis and you can see the name KONI stamped tword the top. There is a manufacture date there as well. I raised the spindle 22mm and added gussets. You can also see my bumpsteer kit.
Gordon ___________________________________ '71 911 Coupe 3,0L outlawed #56 PCA Redwood Region, GGR, NASA, Speed SF Trackrash's Garage :: My Garage Last edited by Trackrash; 08-04-2013 at 05:06 PM.. |
Banned
That looks nice. Mine sure is filthy.
Under the radar
Assuming you had the wheels pointing strait ahead, 1/4" difference is probably within acceptable limits.
Check carefully the tightness of the struts, inserts, and wheel bearings, as they will affect the camber measurements. So pull the wheel and let us know what you find. BTW, that's and old picture of my strut, it's not as nice looking now.
Banned
The wheel wasn't exactly straight. I turned it left about 16th turn and that moved the right up and the left side back. I'll bet that was the 1/4".
What the heck was that guy talking about something being 1" off? Do you still think i need to take it to the frame straightening shop for checking? Or at this point can I assume it is a bent strut? Did you check out the link in post 10? Elephant Racing | Struts and strut services | Porsche 911/912/930 it says Boge struts 69 to 89. I don't see the diameter difference in my strut that you do. I'll pull the wheels and take some pictures. Then I can check for inserts too. Thanks. Last edited by dipso; 08-04-2013 at 05:42 PM.. |
I would toss the Boge and go Bilstein, especially if you're spending money on modifying the struts.
Banned
In the back my shocks are green. That's Bilstein, right. I had them all replaced at the same time. If I have Bilstein shocks in Boge struts, will the existing shocks fit into a Bilstein strut. My head is starting to hurt. |
AutoBahned
I also did the light Al parts thing to my 911 - worthwhile IMO. IIRC, the Bilstein struts are inverted and help with wt. being down low.
could be ball joint time for you also - on mine I just "did a Grady" i.e. injected some heavy oil - there is a pic on my suspension thread I think what you really want is digressive valving what you really want to pay for is... |
Under the radar
![]() I personally have had bad luck with alignment "specialists". Like not checking for loose or worn parts. 1" off sounds weird, especially if you haven't had any problems with tire wear or handling. Bent struts are fairly common, however.
Gordon ___________________________________ '71 911 Coupe 3,0L outlawed #56 PCA Redwood Region, GGR, NASA, Speed SF Trackrash's Garage :: My Garage Last edited by Trackrash; 08-04-2013 at 09:27 PM.. |
Max Sluiter
Dispo, I wouldn't bother raising the spindles. That is only for extremely low cars and when you do it you need to add a bumpsteer kit. I have the A-arms horizontal, standard spindle height, and no complaints about handling that I think a higher front roll center would help. Also, when you raise the spindles you limit yourself to using larger diameter wheels depending on how high you raise them.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
My bet is that your spindle is bent slightly.
12' GT3 18 991S |
Home of the Whopper
Your a arms have the under the body sway bar attachment. The Ts have a through the body sway bar attachment. Not sure about the rest of your stuff.
The wave is not the water. The water merely told us about the wave moving by Buckminster Fuller |
Banned
So maybe struts, balljoints,bushings. Don't raise spindles?
My front is at 24 1/4". I'm on 16's. |
Banned
Just talked to a local used parts supply house.
350.00 a piece for Bilstein struts. 1200.00 for a complete SC front suspension. I would say the complete suspension idea is out. I'm going to call the unibody frame straightening place and see if they can put my car on the rack and tell me if my struts or A frames are bent. |
I would go with Bilstein struts and SC rebuilt calipers, which will require SC rotors. You can re-use your old stuff. I seriously doubt that your tub is welded in 1" off, but who knows.
