db_cooper's Avatar
Originally Posted by Panerai View Post
Db you have a part number for the Bosch injectors they sell for the 3.2?
Regards,
1987 PORSCHE 911 CARRERA, H6, 3.2L, B, GAS Fuel Injectors
These are fuel injectors that fit all 3.2 DME 911s
A google coupon search will get you $20 off a $200 or more Five0 order too. use FACEBOOK20
A little over $400 for six brand new Bosch injectors with coupon
Or get the "Black-Ops M series injectors" (Siemens/Lucas disc injectors..they are a notable design) for $325 with coupon.
Or spend near $180/$200 or more to have your 25 year+ old injectors cleaned
Old 08-07-2013, 04:09 PM
Peter Zimmermann's Avatar
She told me I had more power, greater cylinder fill, and...
Oh, my. You drank Techron? This isn't good, she said Viagra for you, Techron for the car. Oh, no, tell me you didn't give the car Viagra. Be careful working near the tailpipe for the next few hours!
Keep the Shiny Side UP!
Pete Z.
Old 08-07-2013, 04:37 PM
Always Be Fixing Cars
FYI,
Injectors turned out to be pretty healthy. Still happy I had them re-sealed and cleaned.
'91 964 C4 - New Daily
'73 Alfa GTV - 90% done 50% to go
'65 912 - Welding in process
Old 10-11-2013, 11:54 AM
nickd's Avatar
Had mine cleaned on my 80k mile 3.6L. Unfortunately the shop lost the before/after results, but no difference that I could discern upon reinstallation. I run techron through about once per year.
Another 3.6 owner with <100k miles sent his off and they were wildly out of spec.
I would call it a "while you're in there" job.
Not sure if the 3.2 has head temp sensor, but that can alter the air:fuel mix quite a lot and foul your fuel mileage on the 3.6. Mine runs rich and I haven't yet tracked it down. Better than lean I suppose...
1991 964 C4 Cabriolet - drop-top pylon destroyer
Old 10-11-2013, 12:46 PM
Sure does have a CHT sensor and I'm replacing it with a 2-wire as part of my rebuild.
I guess this is obvious (why make two castings) but I was for some reason surprised that each head has the threaded hole for the CHT. So you can run a 6-CHT setup if you wanna get wild. Or stupid.
Old 10-11-2013, 12:50 PM
Had my 88 911 engine with 180K miles out for G50 repair, and while it was out, send injecters to Witch Hunter to clean / test. Report showed only minor improvement after cleaning (best pulsed flow from 105.5 to 108.5 cc improvement) but worth the $138 for peace of mind and new o-rings, filters, and pintle caps. Took almost a month, so plan accordingly.
Old 05-25-2020, 11:29 AM
