Licensed User
Shuie's Avatar
Can I use steel open lugnuts on my Fuchs?
Im planning on installing longer studs in my hubs and have a bunch of steel open lugnuts with the correct ball seat for a Fuchs wheel. Will the steel lugnuts damage the alloy wheel? Can I use these instead of the the lightweight alloy lug nuts? If not, is there a source for open alloy lugnuts with the ball seat for a Fuchs wheel?
TIA
Old 08-06-2013, 12:17 PM
Max Sluiter
Flieger's Avatar
Yes, just make sure to use anti-seize on the ball seat area.
Old 08-06-2013, 12:19 PM
Vintage Motorsport
RichardNew's Avatar
If you race your car or run track events you should be running the steel lug nuts.
Richard Newton
Car Tech Stuff
Old 08-06-2013, 12:35 PM
Licensed User
Shuie's Avatar
Perfect. Thank you for the quick response
Old 08-06-2013, 12:58 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Yep make sure the lugs you use have the correct Porsche ball seal radius.
Take a look at these lug nuts and read the seat size designation Porsche vs. VW/Audi . You have to click on one of the lug nut type and then read the "Detailed Description" tab. There are R13mm and R14mm radius for the ball seat
Results for Ball Seat Nuts:Porsche
14mm Porsche Steel Lug Nuts
Track Studs does a nice job of pointing out the difference between M14 spherical seats. All VW are not necessarily the same/interchange with the Porsche seat shape!
Kevin L
'86 Carrera "Larry"
Old 08-06-2013, 01:06 PM
Some of the steel nuts - T4 VW- are the correct thread and seat diameter but have a relatively shallow dome and it is possible to mark the wheel with the socket when you tighten them up. This is because the seat depth is shallower on the steel wheel.
I am not sure if the nuts Sway Away make suffer from this issue or if it is just the ones made by FEBI.
WE made some in Grade 5 Titanium (6AL4V) with a deep dome to stop this from happening.
86FlatSix
JQ911's Avatar
Very timely. Just bought 66mm studs and thanks KTL for the link on the open steel lug nuts. Any thoughts on the yellow zinc if it would look good on satin black and polished lip 17 replica Fuchs? I see the Singer has longer studs with yellowish nuts.
74 BMW 2002 (rust rocket)
86 911 Coupe (weekend warrior)
09 997.2 C2 (semi-daily)
Old 08-06-2013, 03:30 PM
Vintage Owner
Jack Stands's Avatar
Yellow nuts
I'd worry if my nuts turned yellow!
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 08-06-2013, 03:42 PM
86FlatSix
JQ911's Avatar
LOL! I wouldn't if it turn reddish too much scratching....Ok back to regular programming....
Old 08-06-2013, 03:50 PM
6 cylinder symphony
Gold nuts would look good with some gold PAG wheels
Group 4 Wheels - Reviving historic rally, road and track motorsport wheels
'84 3.2 Targa
'89 964 Coupe
"What do you mean NEXT project?" - my wife
Old 08-06-2013, 06:39 PM
Banned
I bought some of the Ti ones. They are very nice.
Old 08-06-2013, 06:45 PM
AskewRSR's Avatar
I bought a titanium set from Chris. They are very nice.
1965 911 Vin 1249 Slate Grey
1969 911 Golden Green 2.0 Twin Plug
1971 911 S Gold Metallic. Peter Gregg
1974 911 RS Euro Metallic Blue Gold lettering
1991 Brumos 3.6 Turbo Pikes Peak Zwart Motor
Old 08-06-2013, 07:02 PM
DanS911's Avatar
OK sounds like fun... how much for 20 titanium nuts
Dan
'86 911 Targa Driver
'76 911 Targa 3.0 Track Toy
46mm PMOs, 10.5/1 J&E,Web Cams, Wide Body fenders, 23mm and 30mm Hollow T-Bars, 930 Sway bars, Bilstein Sport Shocks, Plastic Bushings (too damn squeeky)
Old 08-06-2013, 08:03 PM
Banned
Read here:
Hey, wanna see a picture of my nuts?
Old 08-06-2013, 08:04 PM
Factory aluminium (53.4g * 20) = 1068g
Titanium after market (18.1g * 20) = 362g
1068 - 362
Saving 706g
Old 08-06-2013, 11:15 PM
