quick question re 88 3.2 engine drop - first time
Just a quick question - I have everything 99% disconnected and ready to drop the engine but while working through the Bentley Manual - I do have some questions about the cruise control.
Where are the vacuum lines that the manual states need removed? I have disconnected the cruise control cable but do not see any vacuum lines for the cruise.................otherwise seems to be fairly straightforward although the engine is not on the ground yet
Old 08-06-2013, 06:44 PM
Member 911 Anonymous
DRACO A5OG's Avatar
It should be on top of the servo. One vacuum and one breather.
'85 Carrera Targa
PCA/POC
Old 08-06-2013, 10:16 PM
MConn's Avatar
It sounds like the Bentley is referring to the pre-1988 cruise servo that uses vacuum - Cruise control parts. My 88 has the square looking CC servo with a big round electrical connector, the accelerator cable, and 3 nuts holding it down.
Mike
The more I learn, the less I know.
Old 08-06-2013, 11:18 PM
DRACO A5OG's Avatar
Mike
+1, just take it slow and double check everything
'85 Carrera Targa
PCA/POC
Old 08-07-2013, 12:45 AM
Don't forget the clutch slave cylinder on top of the tranny. You can unbolt it from the tranny without removing hyd lines and avoid having to bleed it. Be sure to support it. When you put it all back together make sure the pin on the end is in the cup on the fork. There is a removable rubber inspection plug on the side so that you can do this check.
gary
70T coupe forever almost done
88 Carrera Targa diamond blue
Old 08-07-2013, 03:27 AM
Thanks - yep got it - one of my least favourite parts to unbolt. not a lot of room working above the tranny.
Old 08-07-2013, 07:13 PM
Mike
Ok - thats it. What had me wondering is the cruise control has never worked on my car anyways so I wasn't sure if PO had removed anything when I couldn't find the vacuum lines.
Old 08-07-2013, 07:16 PM
Don't forget the stuff in the tunnel: reverse wire, speedo wire, etc.
The oil lines, ground strap, engine harness, etc etc. Go very slow, check and re-check everything the first few inches until you're about a foot down.
Old 08-07-2013, 07:21 PM
Exotic Vehicles are here
1-ev.com's Avatar
have you looked at those articles?
http://www.pelicanparts.com/techarticles/101_Projects_Porsche_911/07-Engine_Drop/07-Engine_Drop.htm
http://www.pelicanparts.com/techarticles/911_engine_drop/911_engine_drop-1.htm
"Y" <- My favorite question...
+ '68 911
+ Helping your business to get more business: http://myWWWapp.com
Old 08-08-2013, 07:19 AM
PCA7GGR's Avatar
tranny ground strap?
Sergio
The GT Lid Whisperer
PCA 42yrs - National DE Instructor / Ex-RGruppe #197
'19 718 Cayman S (9th Porsche/1st with PDK)
'14 Subaru Forester XT (Porsche support vehicle)
Old 08-08-2013, 07:29 AM
+1
I have dropped my engine about three times already. But on the last drop, guess what I forgot to detach?
Oh well, live and learn.
I took off my Cruise by removing the two screws at the cable end where it connected to the throttle body.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 08-08-2013, 07:43 AM
